Speedometer?
Old Nov 8, 2019 | 02:38 AM
Jise21's Avatar
Jise21
Speedometer?
I was wondering if a 1979 f150 speedometer would fit on a 1986 f150
Old Nov 8, 2019 | 07:23 AM
Franklin2's Avatar
Franklin2
Don't know, the guts might if you change the faceplate. Try it, sometimes things work out. Just make sure you spot where the high beam indicator is located. I just bought a 84 Bronco II, and the blue high beam indicator didn't work. Did a bunch of troubleshooting, and figured out it WAS working. But someone had swapped out the speedometer with one that did not have the blue window for the light. I had to take another speedometer I had, pull the needles off, swap the faceplates, and put the needle back on and now it works.
Old Nov 12, 2019 | 05:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Jise21
I was wondering if a 1979 F150 speedometer would fit on a 1986 F150?
No.
1973/79 F100/350 dash and instrument cluster bezels are completely different than 1980/86 F100/350.
The speedometers are different, the gauges are different, the whole enchilada is different. In fact, excepting power trains, 1980/86 trucks are completely different than 1973/79.
Upper pic: 1973/79 // Lower pic: 1980/86.
Neo64
Aug 17, 2018 04:05 PM
gravy31
May 1, 2011 03:01 PM
zpmps2
Aug 19, 2007 10:05 AM
Drac
Mar 13, 2007 01:21 PM
starweb
Mar 31, 2002 10:07 AM
