What transmission do I have ?
Old Nov 5, 2019 | 10:29 PM
xtal_01's Avatar
xtal_01
While the engine is out, I want to put a new seal on the input shaft ... inside of the bell housing is covered in oil (putting a rear main also).
It is a 1986, F150, 4 speed manual transmission, 4 x4 4, 4.9 six.
I went to the Rock Auto site ... lots of choices!
No tag that I can find on the trans but I will look again in the morning.
Thanks ... Mike
Old Nov 6, 2019 | 03:06 AM
Kramercd's Avatar
Kramercd
https://www.fordification.com/tech/transID-man.htm See if this helps.
Old Nov 6, 2019 | 03:57 AM
Rembrant's Avatar
Rembrant
Check the Certification Label on the driver's door frame. It should be close to the striker post on the cab. Do that and post a picture of the shifter and the boys here will be able to help you out. If the shifter is curvy like an "S" then it will mostly likely be the NP435.
Old Nov 6, 2019 | 09:58 PM
xtal_01's Avatar
xtal_01
435 ... what oil ?
Didn't read them message till after I crawled under the truck. Door tag says A
Man ... 33 years of dirt and undercoating can hide anything.
Tag is broken if half but still there.
From what I can still read ...
3TA7003 VA FE3
3 86 435
So 435 it is!
Soooo ... what oil do you put in this thing?
My manual says 80W (1992 and earlier 4 speed ... 1993 and up Mercon) ... is this correct?
Transfer case say Mercon?
Rear ends say "hypoid gear lube" ..... what is this ???
At least I know the engine takes 5w30
Thanks ... Mike
Old Nov 7, 2019 | 12:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1986 F150 4WD 300 I-6 4 speed M/T
TRANS code printed on the Certification Label, glued to the left door face below the latch.
TRANS code A = New Process 435 4 Speed // TRANS code B = RTS TS-OD Top Shift 4 Speed Overdrive // TRANS code F = Borg-Warner T-18 4 Speed.
Old Nov 7, 2019 | 01:25 AM
Kramercd's Avatar
Kramercd
3TA7003 VA FE3
3 86 435
So 435 it is!
Thanks ... Mike
Those sound right, my '85 manual is just a little bit different than yours, but generally the same. Hypoid gear lube according to google is gear oil with and EP(extreme pressure) rating. Like this one https://www.amsoil.com/shop/by-produ...caAnVDEALw_wcB
Old Nov 7, 2019 | 09:47 AM
xtal_01's Avatar
xtal_01
Thanks!
I like the squeeze pack ... might make it a lot easier to get oil into this transmission (I was thinking about how to do that).
Question ... won't 80W-90 be to think to shift?
Long story .. way back in the days before the internet, I change the oil in a manual transmission.
Bought "gear oil" ... probably 80W-90 or something like that.
Could not shift! Took two hands to move the gear leaver.
Went to the dealer and found out is should have been automatic transmission fluid ... I could not believe automatic fluid in a manual transmission.
Never forgot that lesson!
Just wanted to be sure about how thick of an oil to put in.
Just FYI ... I use synthetic in everything ... even the lawn mower.
Thanks again!!!!!!!!!!!
Mike
Old Nov 7, 2019 | 03:25 PM
Kramercd's Avatar
Kramercd
I'd take a length of fuel hose, 1/4" or 5/16" and drill an undersized hole in the lid of a quart bottle of trans fluid. That way you can turn the bottle upside down and squeeze it, turn it upright to fill it full of air so when you turn it back over the air will force the fluid in. Then just swap lids between bottles. Will have to look up what the latest and greatest trans fluid is for the application.
Old Nov 7, 2019 | 03:30 PM
Kramercd's Avatar
Kramercd
He's a nice article, fluids are at the very end. The Novak Guide to the New Process 435 Transmission
Old Nov 7, 2019 | 05:27 PM
xtal_01's Avatar
xtal_01
WOW ... great article!
So 80W-90 it is. I will still go with the synthetic. They say it won't do any harm ... just don't "need" that much protection. Probably the last time it will ever get changed.
One more question though ... For the transfer case they say Mercon.
OK ,,, lots of choices here! Ford (Motorcraft) has Mercon V ... and also Mercon LV (not sure what this is ... not for use in vehicles requiring Mercon V, SP or Continuous chain type) .... Some like Castrol say Dex/Merc ... some say "Multi-Vehicle" ....ATF+4 (also covers ATF+3) ......
I would like to put some kind of synthetic in it ... which do I use?
Thanks again !!!!!!!!!!
Mike
Old Nov 7, 2019 | 05:36 PM
Kramercd's Avatar
Kramercd
https://www.motorcraft.com/us/en_us/...on-fluids.html So this is where I ended up, some of those descriptions contradict what I was going to say... So, here's a list of fluids lol
Old Nov 7, 2019 | 05:43 PM
xtal_01's Avatar
xtal_01
So .... do I choose a Mercon V .... or ?????
Old Nov 7, 2019 | 05:46 PM
Kramercd's Avatar
Kramercd
I'm not going to be able to help with that, the one from the list says not to use in transfer cases. But Mercon V is backwards compatible and yours requested it specific... so I dunno
Old Nov 7, 2019 | 05:58 PM
xtal_01's Avatar
xtal_01
Exactly!
It says not to use but as you pointed out ... backwards compatible!
Maybe someone else can weigh in on this.
thanks again .... Mike
Old Nov 8, 2019 | 11:41 PM
xtal_01's Avatar
xtal_01
Hey!
What do you guys think about this stuff for the transfer case ?????
https://tinyurl.com/y3fmj8qo
It says transfer case oil but then says it does not meet OEM spec. (or at least does not cross reference to them ... reading the answers to questions asked).
Thanks again .... Mike
