Blower Motor Wiring Help Needed
Old Nov 3, 2019 | 02:33 PM
landers0440's Avatar
landers0440
78 F150. Previous owner put a new harness in but the blower motor has never worked/been hooked up. I figured out that the orange wire in bottom right of picture if I supply it with 12V power the blower motor does turn on so I know I’ve got a good motor. The 3 wire plug in top left of pic goes into the heater box but not sure what it’s for? Two of the three wires are hot with key on. I’m assuming 12V from fuse block to switch on dash then to blower motor? Did these old trucks had a resistor anywhere?
Old Nov 3, 2019 | 03:03 PM
alans77crew's Avatar
alans77crew
that is for your resister that helps the fan operate at the different speeds, the resistor is the spade that are sticking up in the picture. if you don't have a wiring diagram go to fordifacation.com and look it up there they have posted them so you can look at them.
Old Nov 3, 2019 | 04:30 PM
landers0440
Do you have to remove the entire box to change the resistor?
Old Nov 3, 2019 | 05:25 PM
alans77crew
no there are 2 screws on the top each end 1/4 drive I think pull those and it come out
Old Nov 3, 2019 | 05:47 PM
alans77crew
if I remember correctly and I probably don't (I'm Old) the orange wire goes into the plug you showed on the bottom it is the power wire to the fan.
alans77crew
I'm sure I have the correct plug for that if you need it.
Motate455
Sep 18, 2019 09:47 AM
stevieb_wv
Oct 2, 2014 09:25 AM
1980 Ford F-250
Jan 25, 2013 12:40 AM
apollo95
1983 - 2012 Ranger & B-Series
Sep 23, 2006 05:00 PM
thenutisloose1
Dec 3, 2005 09:26 PM
