Sponsored by: Real Truck
Diff gaskets
Old Nov 3, 2019 | 12:08 PM
Boaterguy's Avatar
Boaterguy
Diff gaskets
Hey all,
2015 F-250 4X4 powerstroke here. Question for anybody who has used the Lube Locker gaskets. Did you need longer bolts or are the stock ones sufficient?
Also, I havent done this service yet, but have been planning it for a while. Is 64K miles a bit premature? Truck towes about 25% of the time.
Thanks
Old Nov 3, 2019 | 12:52 PM
Keyser's Avatar
Keyser
They are awesome, original bolts work fine if you aren't changing to a different Diff cover.
Old Nov 3, 2019 | 01:50 PM
Overkill2's Avatar
Overkill2
Originally Posted by Boaterguy
Hey all,
Thanks
My thread on using the Lube Locker gasket when I drained mine.
https://www.ford-trucks.com/forums/1...ng-10-5-a.html
I changed mine at 40k ish miles.
Old Nov 3, 2019 | 04:38 PM
Boaterguy's Avatar
Boaterguy
Read your thread, excellent write up.
So there is a plate between the cover and the housing?
I assume it would go cover, plate, gasket to housing.
How do you like the Lucas oil? I was thinking of using it because 44 clams a gallon is way better than motorcraft at 37 a quart. I don't have the elecrronic locker.
Old Nov 6, 2019 | 06:03 PM
Overkill2's Avatar
Overkill2
Thanks. The face of the diff cover is rather thin. I guess that plate acts as a washer for each bolt and gives strength to the OEM cover. Yes you are correct; gasket, diff cover then plate.
I wanted to use synthetic and Lucas came in a gallon bottle. Always heard good things about Lucas so I went for it. And free shipping on Amazon. If you don't have the ELD, then I'd assume you have limited slip. I don't believe you need additive w that Lucas. But better double check first though.
Old Nov 6, 2019 | 06:59 PM
don123's Avatar
don123
I changed mine at 48k it was dirty and used a lubelocker gasket with no mess. No leaks. Same bolts.
Old Nov 6, 2019 | 09:16 PM
Boaterguy's Avatar
Boaterguy
Cool, thanks.
Old Nov 6, 2019 | 09:21 PM
Boaterguy's Avatar
Boaterguy
I think i will give the Lucas a try, because I have heard good things about their products for a while. The Motorcraft is waaayy over priced. Something wrong when the Amsoil is cheaper than Motorcraft.
I have to order another gasket for the front, it should be a Dana 60? My 2015 has an in service date of Nov, 2014, i bought it in july of 2015 wirh 9K on it after it was voluntarily repossessed.
Old Nov 7, 2019 | 09:37 PM
Overkill2's Avatar
Overkill2
I believe the F250s have the 60 also. But to double check, go here and run your VIN to see for sure. I've ordered from here before when I needed mirror parts after I screwed up my passenger side TWICE. When you run the VIN, then search for a diff gasket or front axle parts, it'll tell you for sure what it has. Most likely a 60.
https://www.villagefordparts.com/
Irelands child
Oct 11, 2019 07:15 PM
87&97Aerostrar
Aerostar
Apr 12, 2017 07:27 PM
robert_l_ross
Aug 6, 2013 12:42 AM
quincyjr
Apr 12, 2004 04:54 PM
dclarson
1997 - 2003 F150
Aug 19, 2003 08:17 AM
