Manifold failure
Old Nov 2, 2019 | 09:47 AM
UP_There's Avatar
UP_There
Manifold failure
So my truck started making a really odd sound, on takeoff. It was like a squeal, or a screech. I brought it to my mechanic, and he knew what it was right away. I had two broken bolts/studs on the drivers side manifold. He had me power-brake it, to put it under load, and it would do the screech. Of course I had to see for myself, so he showed me exactly where they were, underneath the turbo. Sure enough, I could see them after he showed me. The squeal sound, he said was the gasket, whistling like a reed on an instrument.
They pulled the turbo, and there was actually THREE broken studs on the drivers side, and two on the other. So I had them replace both manifolds, gaskets, and all new studs. Supposedly, the newer studs are made out of a better/stronger material. Only time will tell! My truck has been babied by me. I asked him what would cause such a thing, and he said even the mall crawlers that never tow have had the same problem. I follow stuff pretty closely on here, and I've never heard about it on FTE! It wasn't a cheap fix, but I'm good to go now!
Old Nov 2, 2019 | 09:58 AM
Overkill2's Avatar
Overkill2
Thanks for making the 6.7 crowd aware.
Old Nov 2, 2019 | 07:15 PM
senix's Avatar
senix
I baby mine and have not heard of this. Wonder if this is something that will become more common as time goes by.
Old Nov 2, 2019 | 08:21 PM
cangim's Avatar
cangim
Neighbors 2011 has the same thing, confirmed broken studs, at this point doesn’t want to fix, maybe next spring we will be pulling a turbo
Old Nov 4, 2019 | 08:39 PM
willydmax's Avatar
willydmax
I repaired the same issue on a 2013 with 136k on it. Not sure exactly what causes it but it does happen. It's not a bad repair. The updated studs are longer and they include a longer spacer, I assume to take up some of the stretch from the heat and cold cycles.
Old Nov 5, 2019 | 12:48 PM
jetskier's Avatar
jetskier
I had mine done at 60k with the leak. I think there were 3 broken bolts total. The rear bolts were broke on both sides. The longer bolts and spacers allow more bolt stretch before failure (strain for you engineers out there).
Old Nov 5, 2019 | 02:45 PM
UP_There's Avatar
UP_There
I guess it's a lot more common then we thought! Well I have all new studs, so hopefully that'll be the last of THAT issue.
Old Nov 10, 2019 | 11:58 AM
jimmystoys's Avatar
jimmystoys
Had mine done about a year or two ago. My mechanic, at my favorite dealer, also new right away what it was. I had horrible visions I blew something due my tuner but not the case. Just broken manifold bolts, driver side. Had it done in just over a day. He also suggested to replace the oil cooling lines to the turbo since he was that far into the repair. I agreed. Runs, or sounds normal now. Hope it doesn't happen again.
Old Nov 11, 2019 | 05:26 PM
Bohen's Avatar
Bohen
Does anyone have a link to recommended replacement bolts? Thank you
Old Nov 11, 2019 | 08:16 PM
UP_There's Avatar
UP_There
My shop got them from the dealership. I don't believe there is any aftermarket support for them yet.
It was definitely an unknown weak link to me on the 6.7. I am amazed to find out how many others have had it happen, after I made this post. Hopefully, it will help someone else, add it to their troubleshooting checklist if they have a similar problem.
kruc
26
Aug 9, 2016 11:46 AM
kyle6241
26
Sep 5, 2013 09:03 PM
Beerstalker
Jun 7, 2007 03:34 PM
Turbo_Whistler
Jan 2, 2005 10:27 PM
