Safety Neutral or Something Else?
Old Nov 1, 2019 | 03:44 PM
h.ubk's Avatar
h.ubk
Hi All,
I have had this truck for a few months and am still tracking down issues in it. One of my first projects was to pull the clutch pedal assembly and lubricate it. When I put it back in, I damaged the plastic piece for the safety neutral. I personally don't care about the safety neutral, so I bypassed it, first with a fuse and then yesterday just by tying the two wires together.
The starter motor always engages for a cold start, but it seems for a warm start a number of times there is no starter motor activity. It doesn't even click. The other day, I tried like a dozen times to turn the engine on and then finally it just turned on. On previous days, I would try two or three times until the engine cranked.
I just replaced my positive battery cable and one of the negative cables. The old ones had corrosion and missing insulation.
Any ideas on where to go from here? I suppose the next step would be to check voltage on the starter motor and work backwards from there to the ignition switch.
h.ubk
Old Nov 1, 2019 | 04:15 PM
willyd520's Avatar
willyd520
Sounds like you got it figured out. If it was your safety neutral switch it wouldn't turn the starter at all. I'm thinking this is a pre-existing issue that the truck had.
I had some ghetto rigged NSS in my truck and you would have to lean under the dash and push the button just to get the starter to turn over. When I did my body swap I just bypassed it completely and have had no issues.
Old Nov 1, 2019 | 04:31 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
IF you are not getting a Clic from the Starter Relay and you know that the Clutch interlock switch is bypassed by connecting the 2 wires together then I would be looking at the Ignition switch in the start position .... I assume this is your 86 f250.
check the wire to the starter relay and the Ground on that Relay too.
I guess I should add... check the linkage from the Lock cylinder to the Ignition switch too, that can be a source of Grief
BigRed26
Jan 25, 2019 08:00 PM
GodsHammer
Aug 15, 2017 01:03 AM
tchalm
Bronco II
Dec 5, 2016 01:41 AM
vector
Oct 18, 2011 03:45 PM
friedslacks
Electrical Systems/Wiring
Jul 14, 2002 11:11 AM
