DEF Freezing
Old Oct 31, 2019 | 10:33 PM
scottz99's Avatar
scottz99
Veteran: Navy
DEF Freezing
Just started wondering about something tonight. I have heard of DEF freezing and I think the truck has a way of keeping it warm when it is running. Is this a tank heater or what? What about when my truck is sitting outside in sub-freezing weather? I've always had a diesel and never had a problem; just wonder why.
Old Oct 31, 2019 | 10:36 PM
mhoefer's Avatar
mhoefer
Tank heater and when you shut it down, it pushes it all back out of the lines into the tank. Then when you start it up, it starts thawing before it starts using it. I’m on my 3rd winter and so far so good. Last winter coldest I experienced was -38 C.
Old Oct 31, 2019 | 11:01 PM
scottz99's Avatar
scottz99
Veteran: Navy
Thanks! So, it is ok for it to freeze when not in use; I guess that is why you are not supposed to top the tank.
Old Nov 1, 2019 | 05:19 AM
senix's Avatar
senix
Here is the key though, Don't over fill the tank. When it freezes, it expands. Plastic tank.
My best advice is to let it run down until it calls for def and then do a complete fill but us the ford filler spout.
the ford spout will shut it off when full, it prevents an over fill and spillage situation.
Old Nov 1, 2019 | 05:22 AM
harmanrk's Avatar
harmanrk
DEF is mostly water. Water expands when it freezes. A full tank, is a risk of a broken/split tank. Leaving room for expansion is a good plan.
Old Nov 1, 2019 | 06:02 AM
nomad_archer's Avatar
nomad_archer
I usually keep mine 3/4 full during the late fall and winter months when freezing is a risk. The rest of the year I keep it pretty full. I have no desire to run that tank very low.
Old Nov 1, 2019 | 06:27 AM
Work Truck Fanatic's Avatar
Work Truck Fanatic
Thats good info. from what I understand engine coolant is routed through a piece of stainless tubing inside the tank
Old Nov 1, 2019 | 08:16 AM
tony m 6.7's Avatar
tony m 6.7
I believe that it is an electric heating element.
Old Nov 1, 2019 | 08:41 AM
dnewton3's Avatar
dnewton3
I know it does. My buddy has replaced his; twice !!!
Old Nov 1, 2019 | 10:52 AM
scottz99's Avatar
scottz99
Veteran: Navy
Is this some kind of special spout? What's wrong with the spout that comes with Blue DEF; I think it also shuts off when full.
I had a buddy that it froze up on while he was driving; I think the tank heater (Dodge) failed.
Old Nov 1, 2019 | 01:28 PM
Fordplatty15's Avatar
Fordplatty15
Blue DEF does not shut off. Buy the Ford spout for about $6 and it screws on the Blue DEF containers. I have 2 2.5 gallon tanks in my garage and I refill them at the pump and store them in the garage till needed.
Old Nov 1, 2019 | 04:24 PM
scottz99's Avatar
scottz99
Veteran: Navy
Ok, thanks, I guess I never noticed it shut off or not because I never add until it can take more than 2.5Gal.
Old Nov 1, 2019 | 04:27 PM
senix's Avatar
senix
The trick is to let it get down to <200 to empty. Then use the ford fill spout on your preferred container. Been doing it this way for 6 years, zero issues.
Old Nov 2, 2019 | 01:24 AM
Work Truck Fanatic
Thats right. The source I got that from has been deemed unreliable
Old Nov 2, 2019 | 02:35 AM
scottz99's Avatar
scottz99
Veteran: Navy
I thought the idea was to not fill the tank? Run it down to a couple gallons then add 2.5gal; leaving plenty of room for expansion (7.5 gallon capacity).
