Baffled
Old Oct 31, 2019 | 05:43 PM
My2sons's Avatar
My2sons
Baffled
So, I recently bought an 89 E-150 club wagon and I think it has had a trans swap. It has an AOD 14 bolt pan but I’m almost positive it should have a C6 3speed everything I can find is pointing to it. It has a 302 edition not throttle body injection. Any help helps.
Old Oct 31, 2019 | 05:44 PM
My2sons's Avatar
My2sons
Efi not edition sorry
Old Nov 1, 2019 | 06:41 AM
meborder's Avatar
meborder
What is the transmission code on the door warranty plate?
what is the shift pattern on the column?
AOD would be PRN(OD)D1
C6 would be PRND21
its possible that someone made a swap, but AOD sounds right for the year. I remember my grandpa having one of this vintage with an AOD, though I don’t remember exactly what year it was. I also remember him having shifting issues until he changed out all the trans fluid. It was very dark and looked like it got very hot more than once.
I mention it because an AOD in that van with a 302 is about at its limit, so some additional cooling and maintenance is probably well warranted.
at least from my experience, YMMV, and others who know more might disagree.
Might not hurt to ask your question in the E series forum as well.
https://www.ford-trucks.com/forums/forum128/
Old Nov 1, 2019 | 07:22 AM
My2sons's Avatar
My2sons
So the trans code is “T” which means AOD, dash pattern matches AOD as well So that solves that thank you now to find a C6....
Old Nov 1, 2019 | 11:59 AM
xlt4wd90's Avatar
xlt4wd90
Great information, except:
1. The column indicator PRN(OD)D1 is 6 positions, just like PRND2L, so either transmission can shift the same.
2. The door tag can say whatever the car came with, but the actual transmission may not match the door tag.
So it's still possible that you may not have what you think you have by looking at those two clues. You really need to take some measurements on the actual transmission, and check against some references, like these:
http://www.crankshaftcoalition.com/w...identification
Old Nov 1, 2019 | 01:54 PM
meborder's Avatar
meborder
He said it had an AOD, why would I question it?
the question was what did it originally have, as he thought it should have had a C6, not an AOD.
The gear shifter says AOD, the door tag says AOD, and the owner said there is an AOD installed.
Im not sure what you are trying to argue about.
Your point is true, though. Because if he gets his way, the door tag will say AOD; the shifter will say AOD, but there will be a C6 in there.
Then the next guy will post up about his AOD not acting right only to find out that someone put a C6 in there.
Old Nov 1, 2019 | 02:07 PM
My2sons's Avatar
My2sons
So after some measuring and cussing, I am sure it is an AOD in my baby, I am still going to find a C6 and I will mark the vehicle CLEARLY in case I ever decide to let someone else buy it thank you all so much I’m sure my problems are far from over but if it was easy everyone would do it
Old Nov 1, 2019 | 02:50 PM
85e150's Avatar
85e150
Something wrong with the AOD, other than it's an AOD? More gears and lockup, depending on your axle ratio that's always handy with a 302. Just a thought.....
Old Nov 1, 2019 | 09:26 PM
xlt4wd90's Avatar
xlt4wd90
Mike, he suspected a trans swap, which is why he's checking. I'm just saying the only way to be sure is to look at the transmission itself, not the door tag, or the shift indicator, which will only tell you what the car came with.
But after measuring the transmission, he's confirmed it's an AOD (no swap).
I also wonder, why the preference for a C6 over the AOD, given the OD, and the locking torque converter.
Old Nov 1, 2019 | 11:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
AOD has 14 trans pan bolt holes, C6 has 17.
Old Nov 2, 2019 | 01:44 PM
My2sons's Avatar
My2sons
The intended result of mixing and matching parts would be a 4x4 van without overdrive I am living in the northeast and need to reach not so easily accessible areas for the work I do. The old girl more than likely won’t go faster than 55 for the rest of her years. All of the help is much appreciated thank you.
Old Nov 2, 2019 | 03:05 PM
NumberDummy
4WD Econolines were aftermarket conversions by Quadravan, Pathfinder, etc.
F150 4WD was not available with AOD, neither were Bronco's, so I doubt there were any Econoline 4WD conversions with AOD
AOD introduced in 1980 FoMoCo Passenger Cars, 1981 F100/150 2WD 300/302, 1983 E100/250 300/302.
restoringmy46
Mar 7, 2011 10:11 PM
Truxx1956
Jul 10, 2008 11:13 PM
fattmann
Apr 25, 2007 03:33 PM
witdog2020
Jan 9, 2006 07:47 AM
elemint
Oct 4, 2004 09:01 AM
