04 Engine knock
Old Oct 30, 2019 | 02:25 PM
Katie Isabel Hunt's Avatar
Katie Isabel Hunt
04 Engine knock
Alright, ignorant question here. I can't find a clear answer to it. So it started off going into limp mode and after a huge ordeal to figure out why, I replaced the fuel regulator spring which fixed limp mode. About 50 km in, she started smoking (white) and knocking...bad. This is exactly what it sounds like(not my truck in vid)>>>>>
Now this all happened almost 2 years ago. The truck has been parked since. I initially assumed it was an injector....as I had a fuel pressure issue right before. Managed to get a quick scan out of the truck before I parked it and it said #2 contribution/balance. Im trying to get the funds together to repair it now but, I'm reading that it may be a bent rod? So my question is, the truck ran fine before I had the fuel issue, is this injector related or rod/bearing related? And what along the line would cause the damage to the rod from a fuel issue?
Old Oct 30, 2019 | 07:31 PM
mattdoc88's Avatar
mattdoc88
Is your knock uneven like that video or is it a steady rhythm?
Does it make the same sound if you crank it with the wire on the passenger fender?
Possibilities include, from least bad to bad:
Bent push rod or broken rocker
Injector damaged
Valve or valve seat damage
Bad lifter
Block or piston damage.
I'm probably missing some possibilities but those are good starting points. I'd do a bubble test in the fuel bowl to confirm driver's side head (you said you have a #2 cylinder code) and then pull the #2 glow plugs to confirm that's the cylinder with the problem. Then from there if that's it, pull that valve cover and oil rail and inspect what you can, down to pulling the injector and scoping the cylinder if you don't find anything up top.
coltac
Apr 8, 2014 11:14 AM
Domino
Sep 26, 2012 10:30 AM
mexicoF250
56
Jun 25, 2010 01:09 PM
wmiller
Dec 12, 2008 06:21 PM
dieselcanuck
Oct 8, 2004 11:34 AM
