Tire Wear
Old Nov 2, 2019 | 04:53 PM
  #31
StonedGrey's Avatar
StonedGrey
Originally Posted by 17 Oaks
Joe is the camber adjustable??? It is OFTEN set at the factory where they build the axle sets, its welded in. Not saying you are wrong, but I have bought Superduty axle sets for the front and they all came to me camber set and welded in.
The Camber & Caster are adjustable via camber/caster bushings where the spindle attaches to the axle. The bushings are round with a hole in the middle. They make multiple different bushings with the center hole in different positions to change the camber/caster.
Old Nov 2, 2019 | 05:38 PM
  #32
StonedGrey's Avatar
StonedGrey
If the front tires are wearing excessively, then there is a problem or alignment issue.
unfortunately Fords alignment “specs” are not really specs. I say this bc the specs are so wide. Acceptable caster(in ford spec) ranges from +2.7- +5.0. Thats a large tolerance.
A Super Duty alignment can be “within spec” and drive like crap and chew thru a set of tires in 15,000 miles. Ford dealer will say, “its within spec”. Means literally nothing. If the toe, camber, & caster are all towards the ends of the specs, then its not aligned. Its acceptable to Ford. Which is not great since Ford doesn't drive the truck nor do they pay for our tires.
my 18 DRW 4x4 PS drove horrible when i purchased it new. Took it to Ford for an alignment and they made it worse. But it was “within spec”. Took it to another Ford dealer. They threw it on the rack and everything lit up green on the machine screen. They handed it back to me. Still drives like crap and chewing the outer edges of the steer tires to hell and back plus it wandered all over the road. Getting blown off roads from honda civics driving next to me. Fun.
Took it to an independent alignment shop. Guy tells me the Toe is dead on but the camber on one side was off and the caster was even on both sides at +3.7. Guy thru in a camber/caster bushing to fix the camber and increase caster on the the passenger front to +4.0 to help fight road crown.
What do ya know, it drives straight now and the tires quit wearing on the outer edges.
When your Ford dealer says its “within spec”, all they are really telling you is, your truck has wheels on the front.
Anyone could assemble a SDuty front suspension and eyeball it within Fords alignment specs. Its a joke.
i run my front tires between 60-65psi towing or not. After a real alignment from the independent alignment shop, the outer edge wearing stopped even with running the tires at %20 below the recommended tire pressure. If a tire is scrubbing(not rolling square)air pressure means nothing.
If a tire is wearing unevenly & theres nothing wrong with the tire, the alignment is off. But on the bright side, your within spec
Old Nov 2, 2019 | 06:18 PM
  #33
DSLTRK60's Avatar
DSLTRK60
There's a wear issue, the stock Michelins Ford provides on the DRW trucks are actually a really good tire, I have 30K miles and they have about 50% tread left. No wear issues on a factory alignment, rotated once.
Old Nov 2, 2019 | 06:29 PM
  #34
Joe T's Avatar
Joe T
Well crap I was gonna get my F150 aligned when it goes in for an oil change this week at the dealership. They better not screw it up. It umm really needs it bad and i dont feel like jacking with it at multiple places.
Anyway, talking about alignment specs. My old Dodge 2500 was like that too. Level the front and set the caster to max spec. Real big range.
Old Nov 2, 2019 | 07:00 PM
  #35
StonedGrey's Avatar
StonedGrey
F150s have an independent front suspension which will have much smaller/tighter tolerances(specs) for alignment from Ford.
Tugly
67
Jan 9, 2015 12:04 PM
Dead Cylon
15
Sep 26, 2014 04:54 AM
FordPS
Dec 17, 2006 07:01 AM
joeycyph56
Oct 10, 2006 08:43 PM
HerbertKornfeld
Nov 29, 2003 07:03 AM
