Excursion starting issue
Old Oct 27, 2019 | 10:44 PM
lquillin's Avatar
lquillin
I have a 2000 Excursion that is having starting issues. I have installed new batteries, new starter, new ignition switch, new ignition relays under hood and dash, and tonight a new ignition lock. I know the new key lock needs programmed but you can avoid it by recoding the lock so can use your old key and I did that. I did try to start it with both key locks old and new before recoding the new one. I’m not sure where to go from here.
Old Oct 27, 2019 | 11:38 PM
RBerry9511's Avatar
RBerry9511
What engine?
Old Oct 28, 2019 | 02:36 AM
mecdac's Avatar
mecdac
Lightbulb
Originally Posted by RBerry9511
What engine?
Best guess 7.3.
Clue (Batteries) and (2000)
How is the CPS (Camshaft Position Sensor)? Does the Tachometer needle move while cranking?
Old Oct 28, 2019 | 02:47 AM
seville009's Avatar
seville009
what’s the starting issue? completely dead when you turn the key? crank but no start? starts and dies?
Old Oct 28, 2019 | 05:51 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Is it starting then dying?
Does it run for a few minutes then randomly die?
Old Oct 28, 2019 | 07:55 PM
lquillin's Avatar
lquillin
What engine?
7.3 powerstroke
Old Oct 28, 2019 | 07:59 PM
lquillin's Avatar
lquillin
7.3 powerstroke
No cranking at all. It would randomly do this but now it just doesn’t start
Old Oct 28, 2019 | 08:01 PM
lquillin's Avatar
lquillin
Originally Posted by mecdac
Best guess 7.3.
Not cranking at all
Old Oct 29, 2019 | 05:56 AM
seville009's Avatar
seville009
since everything is new, maybe check that all of the wiring is connected properly and the connections are tight. maybe a wire got crimped or broken too. it’s possible that one of the new components is bad out of the box
Old Oct 29, 2019 | 10:16 AM
rock2610d's Avatar
rock2610d
Does it click when trying to start it?
Try jumping the starter solonoid?
If it does not crank after jumping solonoid look to starter, solonoid and it's wiring.
A bad key chip will crank but won't start.
If while trying to start the lights dim alot your motor could be locked up or your battery cables are poor.
20 yr old battery cables will have poor connections. Make sure both batteries and all positive and negative cables are good and have good connections.
Ideally post a photo of battery connections for both batteries
Old Oct 29, 2019 | 10:48 AM
2000_Scurge's Avatar
2000_Scurge
You could also try wiggling your shifter or starting in neutral. I just dealt with a similar no start issue caused by the two loose torx bolts under the steering column.
Old Oct 29, 2019 | 06:11 PM
lquillin's Avatar
lquillin
That’s going to be my next task thank you
Old Oct 29, 2019 | 06:12 PM
lquillin's Avatar
lquillin
I’ll check those thank you
Old Oct 29, 2019 | 06:14 PM
lquillin's Avatar
lquillin
I checked all that too they where good
Old Oct 29, 2019 | 06:16 PM
lquillin's Avatar
lquillin
Completely dead when I turn the key. Going to start checking all wire connections
