F250 Newbie Towing Question
Even a bumper pull trailer with a proper weight-distributing hitch shouldn't unload the front end.
Absolutely wrong with a fifth wheel. If the hitch is directly over the rear axle there will be zero change in weight on the front axle. It the hitch is set an inch or two forward of the rear axle, as most are, there will be a very modest increase in weight on the front axle.
You are correct, on a properly installed fifth/goose. Even if he is loaded evenly, is it possible his perception is the front is lighter because of the ride change compared to how much is on the rear axle? In other words, could adding two hundred pounds to the front axle and 1500 to the rear axle still create the feeling of a lighter steer axle?
It sounds like the consensus is that I am not in an inherently unsafe situation given the weight is adequately carried by the rear axle, I am well under specs, and that a lot of people experience a slightly different "feel" when towing a fifth-wheel than when driving the truck without something in tow. I didn't feel particularly unsafe and it may be I just am adjusting to the lighter front end of a 4x2 when I had been used to driving a 4x4 even though my F250 RWD is much heavier than my previous F150 4x4 towing the same fifth wheel.
You are correct, my post needed clarifying. Good call out.
I'm a little late to the party, however, there is a piece of this puzzle that hasn't been addressed yet: Pitch angle.
Take about any car or truck and rake the back end up a couple of inches above normal and the steering will become a little more darty. Take the same car or truck and lower the rear end a couple of inches below normal and the steering becomes a little more numb. In Manana's case, the rear is about 2" lower just by hitching the trailer up, so the steering feel will become a bit numb.
For extra fun, frontal area on the trailer will affect things slightly as well. The more air being pushed by the trailer will act to very slightly unload the front suspension of the truck a little bit as the bottom of the rear tires attempt to pull out from under the hitch that is a couple of feet above. Same goes for climbing grades and accelerating. Braking has the opposite effect.
Either way, for Manana's case, I don't see a problem. This is to be expected.
Ironmanathlete
Fifth Wheel & Gooseneck RV Towing
42
10-19-2019 11:52 PM
ScrambledCJ
09-29-2015 07:16 PM
