I changed the clutch in my 93 ranger 2.3. And I went to pull the shifter out so I could drop the tranny and it came out fine. Now I go to put the shifter back in and it goes all the way into the tranny but it only moves around a little bit. It wont go into any gear. Is it possible that I removed the shifter while in gear and how do I fix this, any info will help, thanks, Jim
Hi jimmmmie; Welcome to the FTE Family!
Check out all the threads in this section, then if you don't find an answer go to:
Ford Truck Enthusiasts Forums > Misc. > Transmission, Differential, Axle and Transfer Case
This section is a more generalized for your type of problem! Happy Hunting!
COME - BACK!
Getting a repair manual will assist you in your future endeavors!
___________________________________________
Take a walk on the wild side + you'll find me there!!
The Brain Is Always On The Move
________________________________________________
My Beastie:
90 Ranger 2.3L EFI 2wd Mazda < with many new parts!
