Sponsored by: Real Truck
transmission leak
Old Oct 25, 2019 | 11:36 PM
Ciro Manganaro's Avatar
Ciro Manganaro
Cool transmission leak
1999 f 250 superduty 4x4 is leaking trans fluid from between the transmission rear and the front of the transfer case. So it appears to be!?!?!?!?!? I parked in in my inclined drive way nose first and when I pulled out there was a 4 in wide 6 foot long trans fluid red murder scene site on my driveway !!! Yikes best cover it up before it draws any attention to neighbors.. Help!>!>!>!??!?!?!
Old Oct 27, 2019 | 11:14 AM
alloro's Avatar
alloro
You'll have to clean off all of the dirt and fluid, then watch closely to see where the leak starts. Until you know that there isn't much to do.
Old Oct 28, 2019 | 07:35 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Without pictures or some other information, I'd guess it is the output shaft seal gone bad.
Old Oct 28, 2019 | 07:56 PM
CousinCarl's Avatar
CousinCarl
This was going to be my guess based on location you describe IF it is truly from here but good advice from alloro... I had a trans line leaking that flowed back making it look like the output seal/gasket. A lot cheaper and easier repair being the line over the output shaft.
sbraatz
Sep 6, 2018 05:21 PM
johnnvegas79
Dec 20, 2017 02:31 PM
BigBlue92
Nov 6, 2011 06:28 PM
papajoemrt
1997 - 2003 F150
Jun 4, 2009 11:42 PM
frdrngrlvr
1983 - 2012 Ranger & B-Series
Oct 15, 2005 03:20 PM
