Interior Door panel Removal?
Old Oct 9, 2003 | 12:54 PM
charlesecarter's Avatar
charlesecarter
I have a '68 Custom Cab that has the chrome trim that covers the screws along the outer rim of the interior door panel. How do you remove the trim without damaging it so I can remove the panel?
Old Oct 9, 2003 | 01:07 PM
heep70's Avatar
heep70
If you can tell where the clips are slid a thin piece of metal inbetween the panel and the trim and push on it (don't pry on it). The clips (if you will) pinch together and will let loose of the trim.
Old Oct 9, 2003 | 02:08 PM
charlesecarter
Did Ford use the same "clips" like used on the wood backerboard type panels to hold the trim in place. I had a '77 Bronco that had the upgraded trim and they used metal clips that "pinched" into the hole and you simply pulled on the area where the clip went into the hole and it popped in the hole.
Is this the same type and they simply used the clips to hold the panel rather than screws?
Old Oct 9, 2003 | 02:17 PM
heep70's Avatar
heep70
It sounds like we are talking the same clip. I never owned a Bronco. Yes, they do the same thing as you described. Or you can do the trick I described above if they are not willing to come out easily. Some of mine are though and a few of them just pop out.
Old Oct 9, 2003 | 08:05 PM
idealtrucks's Avatar
idealtrucks
you said not to pry on them, but when i took mine off and put them back on, i just used a screwdriver covered in black tape(so it wouldn't scratch the paint) and pried them off. They went back on good
Old Oct 9, 2003 | 11:25 PM
heep70's Avatar
heep70
I thought you were having trouble getting them to pop out of the holes so I was letting you know how to get the clips to let loose of the trim. After that you could pull he clips out of the holes. My misunderstanding.
Some of mine where tough to get out of the holes when I first tried. Years of moisture rusted some of the clips ends together.
vidaliaman
Oct 24, 2016 07:57 PM
lafermedavid
Sep 5, 2016 01:29 PM
AGrayson84
May 24, 2016 09:37 AM
chrs2ca
May 23, 2016 10:22 PM
fairlaniac
Jul 3, 2008 02:04 PM
