About had it with this thing!
Old Oct 24, 2019 | 03:12 PM
Meddle71's Avatar
Meddle71
Hey guys I'm the proud owner of a 93 f150 2wd short bed with the 5.8l engine. I truly do love this truck. I bought it with a blown motor, so I replaced it with a good one with less miles. This motor has been gone through with all new gaskets, new distributor, plugs, plug wires, new injectors, fuel pressure regulator(fuel pump and fuel filter also) when I start it up it doesnt want to rev out. I can get it to smooth out but when I try to give it anything it trys to stall out. I'm lost timing chain was not sloppy so I didnt replace that. Help me please!
Old Oct 24, 2019 | 05:46 PM
torq'ta 5 8's Avatar
torq'ta 5 8
welcome to FTE, these trucks are finicky, and awesome all at the same time
1. if truck idles let it get to operating temp and check for codes, even if CEL isnt on could have stored codes
Ford OBD1 Codes and Procedure Fuel Injection Transmission (Mechanics)
2. have you checked that timing is set correct and what its set at
Fuel Injection Technical Library » Setting the timing
3. have you checked fuel pressure with a gauge, should be more than 31psi, and when you give it gas, it should go up
Old Oct 25, 2019 | 08:43 AM
jas88's Avatar
jas88
You are very proud and truly love it, but you are about done with it? Those things do not go together. Patience will help you get it right.
I would have someone spray starting fluid in the TB as you try to apply power to see if it helps or not. That would at least narrow it down to ignition or fuel as the problem area.
volcomstone550
18
Jun 24, 2013 08:15 PM
billyturbo
1983 - 2012 Ranger & B-Series
27
Mar 8, 2010 05:10 PM
dgiusti
1978 - 1996 Big Bronco
13
Mar 22, 2008 09:27 PM
info_napl
Bronco II
Mar 30, 2004 08:33 AM
jjsk8r85
Dec 29, 2003 11:36 PM
