Parking Brake Cable
Old Oct 23, 2019 | 11:08 PM
cybane's Avatar
cybane
Parking Brake Cable
1973 F-250 2WD 133WB. Looking for Left and Right parking brake cables. From what I can tell, I have HD brakes but how do I confirm?
Here is a photo of the setup on the vehicle and the parts catalog, which appear to be the same.
IF I do have HD brakes I believe the part numbers are D3TZ-2A635-H (RH) AND D3TZ-2A635-G (LH).
Does anyone have a good source for the cables? Green Sales, Rock Auto, Dennis Carpenter and C&G do not have them.
Old Oct 24, 2019 | 01:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by cybane
1973 F-250 2WD 133" WB. Looking for Left and Right parking brake cables. I have 12" x 2 1/2" HD rear drum brakes.
All 1973/79 F250 Camper Specials and 1973/76 F250 2WD's with dual piston caliper front disc brakes have 12" x 2 1/2" rear drum brakes, as do all other 1977/79 F250 2WD's.
1973/76 F250 2WD's with single piston caliper front disc brakes have 12 1/8" x 2" rear drum brakes.
1973/75 F250 2WD Regular Cab 133" wheelbase with 12" x 2 1/2" rear drum brakes. Parking Brake Application Chart - Text section 26.2 - Parts list #14D
D3TZ-2A635-H .. Right Rear Parking Brake Cable - 73 13/32" long / Obsolete
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
D3TZ-2A635-G .. Left Rear Parking Brake Cable - 79 13/32" long / Obsolete
No Ford dealer or obsolete parts vendor has any NOS .. None of either side listed on ebay.
Call Green Sales (800-543-4959) and ask them, they have parking brake cables made and they used to have both of these.
Demand probably dropped off, so they stopped making them.
Old Oct 24, 2019 | 03:43 PM
scottscott's Avatar
scottscott
Thanks for posting this, it reminded me that I need to source a replacement parking brake cable for my 1979 4WD F150, regular cab, long bed, left side, rear.
I measured my old, 1979 original cable, it is 66" end to end. Could the numbers experts confirm my assumption that 3TZ 2A635-A is the correct cable for my application? I'm guessing that mine stretched 1/4" over 40 years of use. Thanks!
Old Oct 24, 2019 | 04:03 PM
NumberDummy
Originally Posted by scottscott
Thanks for posting this, it reminded me that I need to source a replacement left rear parking brake cable for my 1979 F150 4WD Regular Cab..
Could the numbers experts confirm my assumption that D3TZ 2A635-A is the correct cable for my application? It's not // It's: 1973/75 F100/150 2WD Regular Cab
D6TZ-2A635-D .. Left Rear Parking Brake Cable - 65 3/4" long / Obsolete
1976/79 F100/150 2WD/4WD Regular Cab // 1976/79 F100/150 2WD/4WD Super Cab.
RPN PARTS in Erie PA has 1 = 888-864-9305.
HAVEN FORD PARTS in Haven KS has 1 = 620-465-2252.
GREEN SALES CO. in Cincinnati OH has 21 = 800-543-4959.
Old Oct 24, 2019 | 04:20 PM
cybane's Avatar
cybane
It does have dual piston front disc brakes and I believe it to be a camper special.
I called Green Sales and they sounded like I was nuts when I asked if they could make the cables.
If you or anyone else has any other ideas/suggestion please let me know.
Thank you
Old Oct 24, 2019 | 04:28 PM
fordguy2100's Avatar
fordguy2100
If you need a brake cable made, call Bruin brakes and see if they can help you. They just made rear e brake cables for my 74
Old Oct 24, 2019 | 04:29 PM
highgirl's Avatar
highgirl
Bruin Brake Cables
https://bruinbrakecables.com/
Old Oct 24, 2019 | 04:36 PM
jakeharp's Avatar
jakeharp
Make sure to remove and measure them before buying anything, i got mine thru rockauto matched up nicely, I should add, that spring was impossible to find, i ended up using one from a Mustang that was similar in length and build..
Old Oct 24, 2019 | 05:11 PM
scottscott's Avatar
scottscott
Thank you ND!!!
rsh1966
May 23, 2019 04:32 PM
my3sonsdad
Dec 21, 2018 12:06 PM
pineconeford
Aug 22, 2017 06:25 PM
BigRyanKP
Jan 27, 2007 03:57 PM
