1994 F350 7.5L coolant leak inside cab
Old 10-23-2019, 06:26 PM
Joseph Valenzuela's Avatar
Joseph Valenzuela
Joseph Valenzuela is offline
Having a coolant leak inside can on the passenger side. Coolant is dripping from dashboard. Any suggestions on what this could be and how to fix it?
Old 10-23-2019, 06:43 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,661 Likes on 1,355 Posts
Welcome to FTE!
It is most likely your heater core.
Moving you to the forum for your truck where you can discuss how to get in there and swap it out.
Good luck with it!
Old 10-23-2019, 08:06 PM
cooksmtn's Avatar
cooksmtn
cooksmtn is offline
As ,mentioned, most likely your heater core.
But,,,,about a year ago on a week long vacation trip in my '91 7.3, wife noticed the smell and a wet spot on the carpet. No sign of a leak under the hood near the heater box. Kept an eye on coolant, ordered a new core, and replaced it. There was no sign of a leak upon examining the old core, looked perfect. Replaced heater hoses while I was at it.
Eventually, I pressure tested the heater core, no leak. Apparently, one of the heater hose connections was leaking, but running down the inside of the firewall into the heater box, no sign under the hood.
So maybe pressure test your core before going to the trouble of removing it.
Old 10-23-2019, 08:11 PM
Joseph Valenzuela
That sounds like a good idea I’ll look into doing that this weekend.
In the excess coolant container it is also turning black not the coolant but the clear tub.
I was told it’s because it’s an older truck and the ground connections could be disturbed? Is that a possibility or is it going to be the head gasket.
BlueBeauty
1999 to 2016 Super Duty
13
10-02-2023 03:22 PM
Richwon4
10-13-2019 11:05 AM
gabbie07
01-19-2017 08:34 AM
cscott952
10-27-2011 11:41 AM
brej
03-22-2005 07:45 PM
Quick Reply: 1994 F350 7.5L coolant leak inside cab
