Sponsored by: Real Truck
Over charging problem
Old Oct 23, 2019 | 05:07 PM
Gerry Lamotte's Avatar
Gerry Lamotte
Hi , not sure what to do next, I have a 01 f250 V10, new alternator new battery, headlights pulse with the voltage 15.5 to 16.1 volts have tried different battery and voltage regulator, and have tried same battery in a 03 crown vic which charged at 14 volts, what controls charging rate, I have been through all the ground wires under the hood still over charging grounding alt to battery no help
Old Oct 23, 2019 | 08:33 PM
Colorado350's Avatar
Colorado350
Welcome to FTE.
It should be the voltage regulator, I would take the alternator off and have it tested.
Old Oct 23, 2019 | 09:15 PM
Gerry Lamotte
Possible I will get one tested , and thanks
Old Oct 23, 2019 | 11:29 PM
droldsmorland's Avatar
droldsmorland
Verify all grounds are good for all the components we are discussing.
clean both ends of the battery cables and the smaller ground wires throughout he system the engine bay etc....
Bad grounds can cause transient voltage spikes or draws which will wreak havoc in modern electronics,
Have the alternator and regulator bench tested?
Old Oct 25, 2019 | 10:24 AM
alloro's Avatar
alloro
A bad ground connection between the engine block and the body is one of the things that will cause the alternator to put out high voltage. You could try using a jumper wire to test this possibility and confirm or eliminate it as a possibility.
Old Oct 25, 2019 | 11:20 AM
redford's Avatar
redford
FTE Leadership Emeritus
Never assume that a new part is a good part, especially electrical components.
Dads76XLT
50
Oct 13, 2016 05:01 PM
drew1
Jan 26, 2015 10:53 AM
dbickford
21
Nov 22, 2013 01:49 PM
phoneman91
May 6, 2010 04:22 PM
joshsombo
Jan 21, 2006 11:34 PM
