Battery help please.
Old Jan 21, 2006 | 05:08 PM
joshsombo's Avatar
joshsombo
Guys I hope that this is alright to post here but I have a 77 RanXLT my battery is boiling over and spitin out when it warms up. I had it tested the other day and it was getting to much juice. seems the alternator is good, I replaced the starter cylanoid, and electronic regulator and still it is boiling and over working the battery. Any idea as to what I should do to solve this? thanks.
Old Jan 21, 2006 | 05:51 PM
460f250's Avatar
460f250
You replaced the voltage regulator with a new one? I guess it's possible it is faulty, not sure what else it could be if the alternator is good too. Battery not overfilled?
Old Jan 21, 2006 | 05:54 PM
LxMan1's Avatar
LxMan1
Check the voltage at the battery with the truck running. It shouldn't be over 14.5v. If so, then you may have gotten a faulty regulator. If the voltage is between 13 and 14.5V, then the battery may have an internal short.
Old Jan 21, 2006 | 09:43 PM
T18skyguy's Avatar
T18skyguy
You might check the wiring between the alternator and regulator and make sure none are broken. Looks like you could have an overvoltage problem which can be dangerous.
Old Jan 21, 2006 | 11:34 PM
Dodge4Life's Avatar
Dodge4Life
My 78 Dodge has a few wiring problems so I've found out about wiring. Replace the voltage regulator if its external. Check that both wires to VR are not reversed. Then check the wireing for fire damage or overheated wire insulation. That fixed my ramcharger right up.
Dodge4Life
