Weak 7.3. Solutions?
Old Oct 22, 2019 | 09:16 PM
airboater67's Avatar
airboater67
I have a stock 2000 f-250 4x4 that I have owned since new. It just rolled 300,000 miles.
Only thing I’ve ever done
to it was removed the muffler. My issue is it just way down on power and not sure what it needs. Turbo, injectors, fuel pump ? Like I said, nothing has ever been replaced and it starts perfect every time . Just seems very sluggish at low and mid throttle. Max boost, foot to the floor is about 14psi. Can’t remember if that’s normal. Seems I need more petal to get it to go. Any suggestions On where to start? I have had the tank out to replace a broken pickup tube and it was all clean. Very clean!
Old Oct 22, 2019 | 09:38 PM
Colorado350's Avatar
Colorado350
Check:
for Boost Leaks: you should be seeing 20-23psi before defueling since you don’t have an OCR.
Up pipes
turbo for play
‘Fuel pressure, do you know what it is?
Fuel filter
Air filter
Hutch/Harpoon Mods when you dropped the tank?
300K is a lot of miles on injectors, how does it start?
Old Oct 22, 2019 | 09:46 PM
airboater67
What is OCR? I don’t know my fuel pressure but I do change my filters regularly .
Hutch/ harpoon mod??
She always starts right up. Even the few times I’ve run out of fuel, she started easily . Thank you!
Old Oct 22, 2019 | 10:38 PM
Colorado350
OCR is a boost fooler so the MAP doesn’t read over 23 psi and cause defueling.
‘Hutch / Harpoon mods, removal of fuel in tank screens, replace with a Racor filter, eliminates air in the system. Just google it.
Definitely sounds like you have a boost leak. Lots of information on how to check for them. Soot on firewall, up pipe gaskets are known to leak.
Old Oct 23, 2019 | 03:06 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Good looking truck! Also did a front end level kit I think.
Completely stock will do about 15 psi. Need a billet turbo wheel to hit mid 20s to get into the PCM defueling situation. Need an aftermarket boost gauge to see it as none was present OE.
With those miles I would expect the up pipe collector donuts are done and the truck is pissing away boost. This would kill performance and be seen with EGT ad Boost gauges. Nice to have all them gauges, but I'd start with new bellowed up pipes because if yours are stock with 300k you definitely need them. Can be had
 for cheap for cheap
with potential work involved, or https://www.riffraffdiesel.com/international-bellowed-stainless-up-pipe-kit-99-5-03/with ease of mind. Or whatever you can find in between. You may be able to see soot on the up pipes or firewall as additional evidence the donuts are leaking.
Polish those headlights with some 100% DEET to clear them up.
That Racor filter Colorado sent a pic of is the best IMO. Mine is still resting on the bench but someday...
Old Oct 23, 2019 | 06:06 AM
airboater67
Thanks, it has a 4 inch lift. Does have boost gauge. By stock I meant drivetrain and engine. I’ve never checked for leaks but I will now !
usa_alex
Sep 26, 2017 09:58 PM
1984_IH6.9_Project
31
Jan 14, 2017 07:21 PM
pwrstroknman
28
Dec 17, 2012 09:16 PM
IHMANKY
May 5, 2010 09:47 AM
big ol' blue
28
Jul 11, 2009 02:02 AM
