Yfa running super lean wot
Old Oct 21, 2019 | 08:20 PM
mathew thomas's Avatar
mathew thomas
I have an 87 f150 with a 300, farmers 4 speed standard trans. Free truck. It was converted to a carburetor before I got it. Long story short. I bought a new yfa and made sure everything was adjusted correctly and installed it. Added a new fuel cell, all new line, and an in line fuel pump. With some minor tuning it Starts and idles good. The auto choke works as it should. Runs down the road but there is a stutter and major power loss when I reach 4th gear. the plugs are telling me that it's running super lean. I can't figure out what's happening at wot. I've tried messing with the float drop with little to no change. I've messed with the metering rod adjustment with no results. The only thing I can think to do is re jetting it. Thoughts appreciated.
Old Oct 21, 2019 | 10:11 PM
mathew thomas
I am also wondering about advancing or retarding the timing just to see what would happen
Old Oct 22, 2019 | 07:29 AM
jackietreehorn's Avatar
jackietreehorn
Timing? What kind of ignition....
Also vacuum leaks?
robs_seven
May 22, 2011 05:25 PM
mattjensen
24
Jan 15, 2009 09:31 PM
tommyleea
Apr 18, 2008 10:18 PM
SMiller
Mar 31, 2004 07:55 AM
camon
16
Mar 19, 2004 01:47 AM
