Rear window install
Old Oct 21, 2019 | 12:06 PM
Subsailor1127's Avatar
Subsailor1127
Rear window install
Okay, did a lot of searching and still a bit confused. I will be doing a rear window install on my '56 and it looks like a pretty easy job. One question I still have is when/where (or if) I am supposed to use the sealant (butyl). It appears that some don't even use it.
Old Oct 21, 2019 | 12:28 PM
CharlieLed's Avatar
CharlieLed
I don't use it because it is a mess and especially for a rear window it should not be necessary. Windshields are a different story...more wind blowing water into the seal, more chance for seepage. A little liquid dish soap helps the seal slide into place and the window to seat.
Old Oct 21, 2019 | 12:34 PM
Subsailor1127
Thanks Charlie, that is what I was thinking, just wanted to do it right the first time.
Old Oct 22, 2019 | 09:38 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Just a FYI the rear glass installs inside out. Glass on the inside, pull the seal lip from the outside.
Old Oct 22, 2019 | 12:07 PM
Subsailor1127
Thanks BJ.
rowyco
May 19, 2017 04:28 PM
Truxx1956
Oct 9, 2007 05:17 PM
christop43
1978 - 1996 Big Bronco
Oct 1, 2002 02:30 PM
texan_eagle_scout
1997 - 2003 F150
Feb 8, 2002 10:34 PM
