Sponsored by: Real Truck
Suspension issue (Turn Radius)
Old Oct 21, 2019 | 06:54 AM
BlueBeauty's Avatar
BlueBeauty
I own a 2003 f250 XLT model with the 5.4l engine in it. Just this past weekend I changed out my front end suspension (Tie rod ends, Drag link, Track bar, steering damper) and installed new front breaks. Due to some play in my steering and wobbliness after going over bumps I took it to the local firestone and they told me the tie rod ends and drag link was shot and my ball joints needed replaced. So I decided instead of dropping 2k I’d spend $400 and a couple hours on my truck myself. Got everything off to my surprise the ball joints where fine the hub assembly needs to be replaced. Haven’t done that yet because I ordered ball joints instead of a hub 😒. Once I got everything back on the steering was tighter and there wasn’t much play at all. However my turn radius to (turning the wheel to the left) was way less than it was before. Turning to the right is no problem. I sent it back to firestone to get aligned and it came back marginally better if that. It’s especially bad when backing up. Any ideas as to what this could be guys? The worn hub that hasn’t been changed the power steering pump?Negligence on my part? Any ideas or feedback would be helpful thanks!
KC8QVO
6.7L Power Stroke Diesel
Aug 27, 2018 01:55 PM
Blue7.3
Australia Chapter
57
Aug 21, 2014 04:42 AM
Redfridge
Jul 2, 2014 06:49 AM
gene2147
Aug 2, 2010 10:20 AM
ponch37300
Oct 11, 2008 02:39 PM
