Sponsored by: Real Truck
Pitarm puller help needed
Old Oct 20, 2019 | 12:21 AM
Vijay's Avatar
Vijay
I recently started project "Iron Bull", that is, installing lift kit on my dually (8 inch lift from BDS) bumper, winch etc. I got all the springs etc installed in front with ease however I cannot seem to get the pitman arm to come out. I tried generic puller (3 prong) and it broke! The tool rental ones at Orielly are too small. Where can I rent one that can pull SD trucks?
On a separate note, I see this:
https://www.amazon.com/Lisle-41970-Heavy-Pitman-Puller/dp/B000ETWGKY/ref=asc_df_B000ETWGKY/?tag=hyprod-20&linkCode=df0&hvadid=312061979255&hvpos=1o2&hvnetw=g&hvrand=3824989085122585146&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031935&hvtargid=pla-570750850698&psc=1 https://www.amazon.com/Lisle-41970-Heavy-Pitman-Puller/dp/B000ETWGKY/ref=asc_df_B000ETWGKY/?tag=hyprod-20&linkCode=df0&hvadid=312061979255&hvpos=1o2&hvnetw=g&hvrand=3824989085122585146&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031935&hvtargid=pla-570750850698&psc=1
This specifically states, 2005 and up. Are the pitman arm different between my 2000 and 2005 SD? I was hoping to finish up the installation this week however a frozen bolt and this pitman arm is holding up the project.
Old Oct 20, 2019 | 01:39 PM
Colorado350's Avatar
Colorado350
@Vijay So you got the nut off? I’ve had pitman arms that absolutely refused to budge. The one thing that has always seemed to work is hitting it simultaneously with 2 large hammers right where it slides on the shaft. Kroil, PB Blaster are some of the better penetrating oil.
Old Oct 21, 2019 | 08:27 AM
Vijay's Avatar
Vijay
I stopped by pepboys and they had large pitman arm pullers(adjustable). It did not work the first time, the grab arm on the puller slipped. I used a G clamp to hold the arm together and then 2 foot braker-bar with a 2 foot pipe at the end of it did the trick. It all came crumbling down!
ashleyroachclip
WTB - Parts & other
Aug 18, 2014 06:08 AM
Hubnut
Apr 10, 2010 05:16 AM
Ford79
Apr 12, 2008 01:25 AM
250SD
Sep 15, 2004 04:40 PM
hobert
Apr 4, 2003 02:02 PM
