Spooks in my van...???
Old Oct 20, 2019 | 07:06 PM
SaltySenior's Avatar
SaltySenior
have a 2008 E-150....every so often ,with the van locked up and the key out , there is static sounds on all speakers..a very short burst about every 15-25 sec. after a while it stops ..going into the van does not stop it....................??????????????
Old Oct 20, 2019 | 07:27 PM
wiskeyVI's Avatar
wiskeyVI
That's Big Brother checking to see if you're really out of the van.
Old Oct 21, 2019 | 05:02 AM
JWA's Avatar
JWA
Does this happen every time or just when in certain parts of your city?
This might be associated with parts of the CAN-bus network or if the factory radio that's acting up---wouldn't be the first time for such a thing. If not factory radio then its from the CAN-bus network. I don't know if there is a reason or a solution for this sort of thing though---sorry I can't be more helpful.
Old Oct 21, 2019 | 08:44 AM
mystbde's Avatar
mystbde
Trailering
Do you live close to high power lines or a cell tower, radio station or next to a power substation?
Old Oct 21, 2019 | 04:11 PM
SaltySenior
there is no power lines or cell tower close by...we have underground wiring in here and this happens when the van is parked in my driveway........?????????
Old Nov 27, 2019 | 03:14 PM
TurboEnchilada's Avatar
TurboEnchilada
Check for parasidic drain or your stereo wiring and make sure its not grounding out or shorting. I had a ranger that had a short and did that.
Old Nov 27, 2019 | 05:19 PM
SaltySenior
the static noise was doing it's thing yesterday after some rain......seems you can adust the volume of the static with the volume **** even though the key is not in and ,of course, the radio is off........where & how do I check for parasidic drain ???
Old Nov 27, 2019 | 08:07 PM
TurboEnchilada
Fist off, check all the speakers and see if its just 1, second, do you have an amp, third, are any wires kinda rough or are the stereo wires not done well. When it comes to electrical there are about a million things they can be. For me it was shotty stock radio wires making contact with metal. Also, it never hurts to check over everything with a multimeter.
Old Nov 29, 2019 | 03:50 PM
Steve Stoltzfus's Avatar
Steve Stoltzfus
Thumbs up
ha ha!!! so funny!!!
Old Dec 3, 2019 | 08:02 PM
SaltySenior
noise is coming from all speakers.......I think I'll just live with it....
Old Apr 1, 2020 | 05:34 PM
SaltySenior
getting worst....it stops after I start up and stays quite the rest of the day..
Old May 22, 2020 | 05:57 PM
SaltySenior
battery dead this AM.....my garage said for me to pull the fuse for the radio and see if it still does it.......2008 e series manual list 3 fuses (#8 , 22 , 37 ) for radio and audio.........any idea which to pull???
Old May 23, 2020 | 04:32 AM
JWA's Avatar
JWA
That's not working out so well is it?
Here:
Perhaps you'd be better advised fully describing what "radio" you actually have: stock OEM or an aftermarket brand? Show a photo of the radio face.
Old May 23, 2020 | 06:57 AM
wiskeyVI's Avatar
wiskeyVI
JWA
Thanks for posting the video link.
Old May 23, 2020 | 11:47 AM
SaltySenior
Radio came with the van as new I believe............no identification on the face....
