2001 ranger tires
Old Oct 20, 2019 | 02:57 PM
jwitty's Avatar
jwitty
2001 ranger tires
Hey guys what are you running for tires? I’m looking for something that is good in snow but still be all season and not have huge lugs. I have the 245/75r16. Thanks guys.
Old Oct 25, 2019 | 11:23 AM
Caplax40's Avatar
Caplax40
Is that size for the Off Road Package? That's what I have and believe the size of tire that is on it. I'm pretty dead set on these for my next set:
https://www.tirerack.com/tires/tires...d&autoModClar=
Old Oct 25, 2019 | 11:24 AM
jwitty's Avatar
jwitty
Yep off road package. Good looking tires but way out of the range I want to spend lol
Old Oct 25, 2019 | 11:42 AM
Caplax40's Avatar
Caplax40
Out of curiosity do your current tires rub at full lock? Mine do and it has bugged me since I bought the damn thing in 2002.
Old Oct 25, 2019 | 11:44 AM
jwitty's Avatar
jwitty
Nope no rub at all and never had any.
Old Oct 29, 2019 | 01:07 PM
Dhagerty40's Avatar
Dhagerty40
these are the tires I just put on my truck. I have LT tires on mine, but they also make a standard tire. I was surprised they were as quiet as they were. I also have the same size rim as you.
https://www.falkentire.com/tires/lig...peaka/t3w-tire
Old Oct 30, 2019 | 05:52 PM
DIYBob's Avatar
DIYBob
I also just installed Falkens on my 2001, but I have 225/70 R15. Got them on Amazon ($78 ea.), installed by Sears ($15 ea). This was the best deal I found after shopping all the local tire companies.
Old Oct 31, 2019 | 08:56 AM
SirArgus's Avatar
SirArgus
I live in Norway and i've been driving in all kinds of weather, i've tried alot of different tires and i can tell you from experience that there is no good all season tire, you will be making compromises.
That being said a all terrain would be your best shot, preferably something that's had a design update recently.
pawpaw's Avatar
pawpaw
At the suggestions of multiple guys on the old Motor Week forum, I'm running Michelin LTX M/S in the factory specified 225/70/15 size, on my 99 4.0L 4dr with the 5R55E tranny & Payload Package-2 & Tow package.
Wet traction is Way better than the Firestones it was delivered with & so is the ride & handling when towing the Bass Tracker in the Blue Ridge Mtn. twisties. No problems on wet boat ramps when launching or retrieving the 175 Tracker.
I haven't tried driving it in snow, as I know it would likely be a problem without a couple hundred pounds in the bed over the rear wheels.
Wear has been even & the sidewalls have held up just fine from dryrot cracking. Only difference I've noticed is there is a brief low speed tread hum speed range they go through just before coming to a stop on some road surfaces, not really objectionable, just there on my Ranger.
I caught these on sale some years back at Tire Rack for $72 US ea & even with shipping & having my local garage mount, & balance, it was well over $100 less than any other tire place would quote on the same tire.
It didn't take much weight to balance each of them & they've remained in balance. Belt alignment was spot on & the splices were even & smooth, so build execution was spot on for my set of 4.
The Motor Week forum guys were right, they were a Big improvement over the Firestones that were down right dangerous on a wet road. Firestone ride & non towing handling was ok & the wear was too.
I'm not a Michelin fan boy, but these LTX M & S have been excellent & have done everything I've ask of them over the years & they sit outside year round.
So if you can catch them on sale, maybe jump on them like a duck on a June bug, as I did years ago.
Old Nov 1, 2019 | 11:09 AM
Dhagerty40's Avatar
Dhagerty40
pick your tires based on the driving conditions you will be having. check the ratings and specs and pick a tire best for your conditions.
I picked my tires mainly because I am going to be doing a lot of towing over the next year and also a lot of loose sand (moving next to a desert). I will be seeing almost no snow.
Old Nov 4, 2019 | 06:43 AM
97ranger xlt's Avatar
97ranger xlt
i ran firestone destination a/t's on my '97 which were very good but when it came time to replace tires on the '02 they got too pricey.
i ended up with P245 75 16 kumho road venture at51's and very happy with the the performance in wet,dry, and snow. been on for 2 years and
wear is also good.
lrd56
Dec 10, 2006 09:09 PM
mustangmike
May 5, 2006 09:09 PM
SCS99F-150
Aug 3, 2003 04:33 AM
mcmenakim
May 10, 2002 09:54 AM
