2007 Ford F150 2WD Lift Options
Supreme Suspensions - Ford F150 Lift Kit 3.5" Front Lift Billet Spacers + 1.5" Rear Lift Steel Blocks (Black) Leveling Kit 4WD PRO https://www.amazon.com/dp/B00V5J6NCY..._AuqdQsrDCBRej
Sorry I didn't see the 8 inch left part when I'd copied this to clipboard
For the rear We disconnected all 4 U bolts (2 on each side of axle) used a farm jack to lift truck by the trailer hitch, took out old blocks, put in new, let down bed and put on the U bolts that came with kit from above post. By the way use loc tite or double nut the U bolts as mine come loose at one point, thank God We were on the deer lease going 3 mph when the rear end come loose and tire started scraping the back of fender. Oh yeah there's a metal cradle plate under axle that goes on U bolts, just transfer that.
https://www.harborfreight.com/42-inc...saAnhyEALw_wcB
Not sure if this jack can handle vehicle weight but it's the style We used to get the truck lifted off rear axle after U bolts are out. I did this write up for anyone searching lift and wants to do it themselves. Would be nice to see the 8 inch write
Can I ask a question? I'm not trying to be rude or anything but I've always wondered this.
Why do people lift a 2wd truck? 4x4 I get, but 2wd?? I grew up in the 80's, I remember that nothing was cooler than a lifted 4x4. But then I moved to the south and see people doing it to 2wd trucks and I just wondered what's the point. 4x4's are in theory going to off road or go mudding, etc. The 2wd isn't going to be doing much of that lifted or not.
I'm not saying someone is foolish to lift a 2wd. It's your truck, do what you like. Not judging from me. I just wanted to learn a bit about why. Is it just for looks? Do you do something with the truck that lifting helps? Just curious!
Pops always said growing up if You had a good sized lift with 36"-44" tires on a 2wd, copious amounts of horsepower/torque and a lot of weight in the bed that You'd sink, grab and tear on out of some mud. Said He'd always enjoyed the lumberjack work with Great Uncle as they'd surprise the heck out of the 4wd crowd at times. Great Uncle always used Mickey Thompsons. Before my day and age so just relating. I've seen the pics of the trucks and they were some bad boys, enough to inspire me to have 3 trucks now with 3.5"-8" lifts, one 4x4, one 4x6 and one 6x6
Why lift a 2wd
Fair enough. I kind if assumed it was more for looks but I honestly didn't know.
I live in SC now but I am from Vermont. Over the years there's been less and less 2wd trucks up there but nobody ever lifts one there. Usually if anything, 2wd trucks get dropped, the 4x4's go up.
For me personally, I'm not a fan of a lift unless it's mild. At a point the height makes a truck unusable as a truck. You throw a 6"+ on a truck it makes using the bed a little difficult, and towing could be compromised as well.
But that said, I get why people do it and certainly wouldn't think anyone is foolish for customizing their truck! It's yours, make it how you want it!
[/QUOTE]Why do people lift a 2wd truck?
im 6ft 11 and i want my truck just a tad over me.
[QUOTE]
Depending on what you are doing, 2WD is sufficient, and 4WD may not be needed. Lift offers clearance. You don't worry about bottoming out over uneven terrain. Lift allows for larger tires with more aggressive tread patterns.
Most lift kits are 6" lift. Use a kit of some sort. Do not modify or alter suspension components which were only designed to be installed as is. So don't get a 6" lift kit, and stack on 2" spacers. Do not try to combine a suspension lift with a body lift. Do not try to add 2" spacers to adjustable shocks.
I believe that the 6" lift kits with 35" tires are the most "functional". A better engineered kit will also come with new suspension components. A suspension lift is better than a body lift. But that is just my opinion.
I see that there is a lift kit manufacturer which has a kit for 10" - 12" of lift, and 38" - 40" tires. https://www.bulletproofsuspension.ne...50-10-12-inch/
Consider that you have a truck that is over 10 years old. By the time you install a lift kit, new wheels, new tires, regear the rear differential, and buy a tuner to recalibrate the truck's speedometer - is that total cost what you really want to spend on a 10 year old truck? Cost should be a factor in making this decision.
[QUOTE]
Whats the best way to get my 2007 Ford F150 2WD to an 8inch lift!?
Thanks for the response & input. Thats the exact setup i am going with 6inch lift with 35" tires & maybe 22 or 24" wheels but haven't decided yet. I've done a lot of research & homework on lift trucks and I'm well aware of the do's & don'ts. Body lifts was never going to be an option for me. I want to achieve a natural suspension lift, i feel like body lifts is cheating to truck lifting.lol. and i totally agree with not stacking spacers, theres no point in putting stress and more than likely damaging important components just to achieve a lift. And yes my truck is a little over 10 years but its the make and model that i wanted my project truck to be. To be a 10 tear old truck it honestly still has the ride quality of a brand new truck, the triton is running great, transmission the same interior looks brand new just was an all around great buy and awsome truck and after doing math on doing what i want to achieve its well under what i would want to put in a vehicle this age. Also thanks for the link.
caleballen95
01-24-2015 10:22 PM
300-6 AUTO TECH
11-20-2006 04:19 PM
