Front springs
Old Oct 18, 2019 | 10:33 PM
Dieseln00b's Avatar
Dieseln00b
Front springs
Hi everyone. I am looking at upgrading my shocks in the near’ish future.
What are people’s opinions on the front springs? Is it something to look at switching, if I do upgrade the shocks. I have read and heard a few times the stock springs on the 350’s are overkill b/c they know the shocks are weak. Granted it’s a ‘work truck’
There is a Carli spring, but I want to keep it stock height.
Thanks for any input info and opinions!
Old Oct 19, 2019 | 12:02 AM
HRTKD's Avatar
HRTKD
In general, the stock shocks suck. Almost any aftermarket shock will be better than the OEM.
What problem are you trying to solve?
I have yet to hear that the springs on the F-350 are "overkill" to compensate for the weak shocks. The springs on the F-350 are there for increased loads that may be put on the front axle, such as a slide-in camper.
Old Oct 19, 2019 | 06:52 AM
Willy Sunshine's Avatar
Willy Sunshine
Spring and shock absorbers are very different and do different jobs. Both are necessary. The heavier the truck springs, the less the shocks can do. Stack up 9-10 leaves and no shocks.
My new F-350 rides great. Could not ride better or have a more solid feel. The engineers and builders did a great job.
Old Oct 19, 2019 | 08:44 AM
Dieseln00b's Avatar
Dieseln00b
So from my knowledge... - springs hold the truck up, absorb the bumps and the shocks help dampen the bumps and the recoil of the Springs.
going to a beefier shock like the fox 2.5 (for example) would help dampen the bumps etc, so I guess my question is would it be beneficial to goto a slightly lighter spring?
I drive gravel roads roads a fair amount in the summer and the truck sucks on them. So I would like to improve that.
I believe my trucks a 5600lb spring (front) and I was debating a 5200lb spring if I swap the shocks. And I want to keep the stock height for towing. I put a bunch of sandbags in the box when it’s unloaded.
Old Oct 19, 2019 | 08:58 AM
HRTKD's Avatar
HRTKD
Before changing the springs, I would change the shocks. An aftermarket shock like the Rancho 9000XL is adjustable and may be a good fit for you if you're trying to dial in a specific ride quality. Fox makes an adjustable shock also, but it is much more expensive from what I hear.
One warning I'll throw out is if you put in shocks (and springs?) that are too weak you may be setting yourself up for death wobble. I had my Rancho 9000XL shocks set too low and experienced death wobble. Once I increased the setting, I haven't had a problem in the past two years.
Old Oct 19, 2019 | 01:10 PM
Dieseln00b's Avatar
Dieseln00b
Perfect thanks! I didn’t think of that. I’ll do the shocks first and see how it goes from there.
king-david
Jun 19, 2014 05:31 AM
ToyhaulinEX
Feb 23, 2012 04:38 PM
Ford XLT 4x4
Sep 21, 2011 09:42 PM
2manykids
Dec 31, 2007 05:49 PM
braineless
1983 - 2012 Ranger & B-Series
Apr 17, 2004 08:27 PM
