2020 Chevy 6.6. gas
2020 Chevy 6.6. gas
Was on https://www.tfltruck.com/ watching a tow test for the 2020 3/4 6.6. gas pulling 16k up the Ike Gauntlet. The truck slowed down to 30ish with the gas on the floor. The Chevy had a 3.73 gear and a 6 speed trans which is probably ok in less altitude.
I sure hope the 7.3 performs better pulling 16k. I ordered mine with 4.30 gearset which will be a benefit.
16K is a lot for a gas truck especially pulling that kind of a grade. The 7.3 should perform better but I would expect no walk in the park under those conditions. A 4:30 rear end while generally better for heavier towing may not help much if the RPM's are close to the same going up a grade at a given MPH because the transmission in the 3.73 could be in a lower gear to get close to the same torque multiplication.
I think the 3.73 is terrible for gasser towing, especially uphill at high elevation and the large tires that trucks come with nowadays. That's a commuter gear imo. I don't know what the torque curve of the 6.6 is but I was happy with the 7.3 curve which is why I ordered it. Got the 4.30s too. I won't have to tow 15k up the Ike but the 7.3 and 4.30s will suit the smaller hills and 8k trailer we use.
Yeah, I am not fond of 3.73. GM should have left well enough alone and still have the 4.10 as the standard diff ratio. I am just researching out the Ford SD offering, especially the new 7.3. I typically run my 2015 Chevy 2500 6.0 in manual mode and not let it go into top gear. Even with the 4.10 ratio. It is better for the rolling hills in my area and cuts out a lot of unecessary shifting which leads to a cooler trans and, surprisingly, better overall fuel economy.
I am interested in the 7.3 gasser and the 10 speed that Ford is bringing out. Still looking at overall specs and capabilities. The 6.6 L8T gasser in the GM line is interesting, and similar in performance, but GM is using a beefed up version of the 6L90 6 spd. That motor really should have a 8, or better, a 10 spd behind it. GM probably has that in mind in the future, but it is not an offering yet.
