2019 7500 miles
It started with my rear drivers door and now all doors are dripping out of the door covers underneath. Carpets are all dry but I assume this will get worse and water will make it into the channel along the door openings
I have water that stays on the top of the door seal and drips in once you open the door (I notice it on the driver rear, but that because I open it often to throw stuff on the backseat). Might also be from how I park, but it's pretty level. I also notice the door or door lower seals hold a bit of water too. The drain ports on the doors are clear. I don't get any water inside other than what drips in when i open the door.
I would say this is my biggest gripe with my 2017. The door seal design stinks. I noticed my door is still leaking a bit of water from door panel. I need to take mine back in again. Or I may just fix it myself haven't decided yet. I believe the fix is more or better butyl tape that seals the vapor barrier to the door.
It’s not currently making it into the truck but during a heavy rain last night it made it onto the top lip. I guess I’ll make an appointment for all the doors
Both my rear doors had water pooled in the wire trough under the sill plate. Dealer was able to reseal both doors. Drivers side is completely dry now. Passenger side has a much smaller leak than before. I may just pop the trim cover off that door and see what I can do. Not interested in the dealer keeping the truck for a few days again.
