Random no start
Old Oct 15, 2019 | 07:33 PM
bismic's Avatar
bismic
Originally Posted by drinkerofstone
A question that you guys may have missed a couple of posts ago... what commands the buzz test to happen? Should it happen every time the key is turned to on?
I lose track of the strategies for "buzzing". My 06 doesn't buzz every time the key is turned on.
Old Oct 15, 2019 | 07:41 PM
Visurveyor's Avatar
Visurveyor
My 2004.5 does not rather. Just fuel pump.
Old Oct 15, 2019 | 08:33 PM
drinkerofstone's Avatar
drinkerofstone
Originally Posted by bismic
In the old days it was a LONG debate over where the rpm signal came from. Also, lots of folks look at cam and crank sensor codes as an indication of a problem w/ those sensors when some of those codes simply come from a stall or excessive crank situation. A lot depends on the exact code number - which is always a good thing to post.
I wouldn't expect an injector pulse width value if there are sync issues.
Good point on the trigger wheel. Often times if that wheel has an issue, then there might be cylinder contribution codes on "opposing cylinders" in the firing order.
So are you saying that you are 100% sure that 100% of the rpm signal is coming from the crank sensor on this engine? If so, what are your qualifications to say so? I only ask because when I come at my Diesel mechanic with this info, I don't want to tell him.... ya, I heard it from some guy on a forum..... lol!
Old Oct 15, 2019 | 08:43 PM
drinkerofstone
Originally Posted by Visurveyor
Well on that reply I would say do the old BYM trick. If you really are down to electrical issue.
When the crank no start happens, get under the hood and wiggle the harness. See what happens.
Next alternative would be just buy a harness or do some serious electrical diagnostics. I guess I would have pcm checked also. Probably do that first.
The shutting down at the light while running still has me thinking loose connection somewhere. Maybe a ground. You have two write there close to pcm.
BYM trick?
-Ya, ive tried to make it stumble or fail when it is running by moving around wires, pushing them against stuff, ect….. however, armed with this refreshing information, I think I will look more closely at the Crank sensor connector and wiring.
-The shutting down thing only happened the first day that it started this saga, never happened again in the probably 3 months since.... so maybe there was another problem that got fixed along the way of all the troubleshooting that has been done.
Old Oct 15, 2019 | 08:45 PM
bismic's Avatar
bismic
Just tell him to read up in the Ford PC/ED manual and in the FICM Guide.
Also, in the PC/ED manual it states: "Engine speed is determined by counting 15 windows on the crankshaft gear each crankshaft rotation" on page 5-68.
The WSM states: No SYNC and no RPM signal, typically is a faulty CKP sensor/circuit problem.
FICM Guide:
"SYNC is achieved when the PCM receives a signal from the Crankshaft sensor (CKP) indicating the sensor is working and the correct signal has been identified by the PCM. If the Crankshaft sensor is working improperly, the PCM cannot calculate engine speed or cylinder position, preventing fuel delivery."
https://mid-atlanticema.org/wp-conte...Tech-Guide.pdf
Old Oct 15, 2019 | 08:53 PM
drinkerofstone
I got P2614
Old Oct 15, 2019 | 08:54 PM
Visurveyor's Avatar
Visurveyor
You asked Drinker. 😅 ya went and poked the Bear.
Trust us, If Mark puts out info it's about 95% chance he knows what he's saying.
But we have to ask.
Old Oct 15, 2019 | 08:55 PM
bismic's Avatar
bismic
That is the one that can be generated by excessive cranks or after a stall event. It could even be caused by a shorted out injector coil.
Old Oct 15, 2019 | 09:00 PM
bismic's Avatar
bismic
But we have to ask.
LOL - no one is 100%! I've even seen folks take a poll and the greatest response was wrong. Even DieselTechRon stated that the 04.5 HPOP came with the failure prone STC fitting that was updated w/ the one-piece fitting (and a few other things that weren't correct). It happens!
When you come to the internet, you should always verify if it will cost much money.
drinkerofstone
But we have to ask.
well, I just know from personal experience in my shop, that when a customer comes in and starts spewing information at us and said he read it on a forum, we usually roll our eyes and say... ya, ok.... there is just as much bad info out there as there is much good, and then show them the real info..... so, that's why I don't want my mechanic to have the same reaction. lol!
Old Oct 15, 2019 | 09:01 PM
bismic's Avatar
bismic
well said!
Old Oct 15, 2019 | 09:03 PM
drinkerofstone
Yes! this is why I don't want to just toss new harnesses at it and blow 1000 bucks, and have it be something fixed way cheaper! lol!
Old Oct 15, 2019 | 09:08 PM
  #28
bismic's Avatar
bismic
You can get OEM Ford parts from AutoNation White Bear Lake (internet sales) for a lot less than retail.
The main engine harness for your 06 is part number 5C3Z-12B637-BA - if you wind up needing it. Before going that route, there are electrical tests that should be done.
At AutoNation WBL that harness is $636.
https://parts.autonationfordwhitebea...y-5c3z12b637ba
Old Oct 15, 2019 | 09:33 PM
  #29
drinkerofstone
What electrical tests do you recommend? ....I may have did a few already from other forum posts I've found....
Old Oct 15, 2019 | 09:43 PM
  #30
bismic's Avatar
bismic
The attachment is from the WSM.
File Type: pdf
