Does my fuel filter really need changing now?
Old Oct 15, 2019 | 09:38 PM
Redrockerstl55's Avatar
Redrockerstl55
Can’t beat that amazon price. All in it is even better than diesel filters online which is where I usually buy.
I would change them around every 20,000.
Old Oct 15, 2019 | 10:44 PM
Work Truck Fellow's Avatar
Work Truck Fellow
This is one job that I will always do on my on because you pay for an hr of labor for a 15 min job. Its really easy to do.
Old Oct 16, 2019 | 06:21 AM
slowfarmer's Avatar
slowfarmer
Here is a document explaining how to change both filters. Its super easy dont pay $200+
File Type: pdf
Old Oct 16, 2019 | 09:24 AM
Fr8dog69's Avatar
Fr8dog69
Just changed both of my fuel filters at only 15k miles. Purchased them on amazon for around $52. Cheap insurance against injection pump and fuel system failure. Luckily, I have a late 17 job 2 truck and it has the anti siphon valve installed.
Old Oct 16, 2019 | 09:35 AM
BillyE's Avatar
BillyE
My manual says 30k miles so that's what I do. It's not being cheap to follow the manual. I'm not sure where all the other recommendations are coming from. Failing to change the filter does not result in trash making it into your injectors. Changing filters too much adds risk because each time a line is broken, there is a potential for foreign matter introduction. If you fail to change the filter, you'll get the same error as gelled fuel--low fuel pressure. I hope this helps.
Old Oct 16, 2019 | 09:44 AM
HRTKD's Avatar
HRTKD
The instructions you provided seem clear. I thought I had seen a recommendation to "lubricate" the gasket in the lower filter housing with diesel fuel before installation. I don't see that in these instructions. Is that a valid step or not?
Old Oct 16, 2019 | 10:11 AM
jdwheels's Avatar
jdwheels
I have had luck with my early 2017 by letting the fuel tank go to about 1/4 full before I change my fuel filters. Maybe a 1/4 gallon of fuel drains out.
Old Oct 16, 2019 | 12:57 PM
nomad_archer's Avatar
nomad_archer
It takes me about a 3 - 4 weeks to get to 1/4 tank. I guess I will have to plan accordingly when its time to change them on my early '17 build.
Old Oct 16, 2019 | 03:47 PM
Shady Camper's Avatar
Shady Camper
Same here on my early '17. I ran it below 1/4 tank once I hit 15k on the clock and no problems. Got one mason jar full of fuel, then the rest was easy. I buy all my filters from www.dieslfiltersonline.com. I got a counterfeit Motorcraft oil filter from Amazon, so I will never buy filters from there anymore.
Old Oct 16, 2019 | 05:50 PM
tortue71's Avatar
tortue71
I had fuel gell up on me and never had any warning of any kind
Old Oct 17, 2019 | 06:30 AM
Cpt. Slow's Avatar
Cpt. Slow
Thumbs up
Finally! Someone who understands how filters work.
Old Oct 28, 2019 | 06:02 AM
Mainedieselman's Avatar
Mainedieselman
Talking Early 2017 Fuel Filter change
Many thanks to those that have posted suggestions on dealing with the challenges associated with early 2017 fuel filter changes. Enjoyed success on my 2017 extended cab, 6 3/4' bed, with 29 gallon tank AND skid plates, by waiting until tank was below 1/4 full. I don't think I got more than a pint and 1/2 to drain before it stopped. HOWEVER when I went to remove the filter I found I could not access one of the bolts without removing a metal guard that protects the drain valve. A bit of a PIA with two screws, one of which was difficult to access. Once the metal guard was removed the filter change was very easy and to my great pleasure both fuel and filter were very clean (I frequently drain about six ounces to check for water and dirt). Upon replacement I did the following: put some anti-seize lube on the threaded receiving end of the five filter bolts (they're open to the environment at the top and collect corrosives from road spray) and replaced the two screws holding the metal guard in place with hex head (5/32" or 8MM) #12 X 3/4" SS self tapping screws. These challenges may be unique to the cab/bed configuration I have. I too use dieselfiltersonline because I get EXCELLENT service and fair prices.
Old Oct 28, 2019 | 04:30 PM
  #28
srkr's Avatar
srkr
I have the Ford dealer do mine every other oil change (when truck says to change oil) close to every 15K.
Old Oct 29, 2019 | 07:54 AM
  #29
mbell5263's Avatar
mbell5263
Originally Posted by Larrymac52
I have a 2018 F350 6.7 with 16k average miles in 16 months. No towing— mostly a 50/50 mix of in town on on interstates. Been using the PM2 cetane boost from Motorcraft.. So is this urgent or could I safely go another 5-6k?
My local dealer says it’s a $225 job. Is that about right?
Does anyone know the part # and where I could buy it cheaper?
I have been getting my OEM oil filters from Amazon cheaper.
Yes, replace them and make sure you replace both filters. Some independent shops will replace 1 but not the other.
Old Nov 5, 2019 | 08:01 AM
  #30
Lamoon78's Avatar
Lamoon78
I’m a maintenance stickler oil change every 6,000 regardless of what the oil life monitor says and fuel filters at the next and have never had any issue with my diesel trucks. Ford puts long interval down hoping your basically dumb enough to follow it. Just like tranny 100,000 miles before change I don’t think so.
Kevo101st
Apr 22, 2016 02:34 PM
montey2005
6.7L Power Stroke Diesel
Jun 23, 2015 08:23 PM
mairskin
Sep 17, 2011 06:10 PM
xfrank12
General Diesel Discussion
33
Nov 28, 2006 10:07 AM
westladog
22
Feb 27, 2005 09:02 AM
