Sponsored by: Real Truck
Hanging Idle
Old Oct 14, 2019 | 05:56 PM
SMarquez's Avatar
SMarquez
Hanging Idle
2000 F250 6.8l gas, 200k miles. It just started happening yesterday. After running down the highway and coming to a stop the idle seemed to be hanging about 16-1800 rpm. It took a little more effort to stop. I slipped it into neutral and gave the throttle a couple taps and the rpm came down but not like normal. It did this two more times but not as high in the rpms, maybe 1400 on the tach. I'm 1300 miles from home and limited tools with me. So far, it hasn't happened today. Any ideas on where to check that hopefully won't involve a shop if it starts acting up again? I do have a VOM and code scanner.
Thanks.
Old Oct 14, 2019 | 06:23 PM
Juneaudave's Avatar
Juneaudave
Idle Air Control valve (IAC) maybe. Look for a P0505 OBD-II code if you are seeing a check engine light.
Old Oct 15, 2019 | 08:47 PM
SMarquez's Avatar
SMarquez
Nothing on the dashboard but will check for codes tomorrow anyway.
reamer
2015 - 2020 F150
Jul 26, 2019 05:18 PM
CA-F250
6.7L Power Stroke Diesel
Nov 18, 2012 07:22 PM
spd800
Modular V10 (6.8l)
Aug 21, 2007 09:51 PM
Big Red F250 SD
Aug 17, 2004 10:54 PM
randy52064
1997 - 2003 F150
Nov 30, 2003 09:45 AM
