Turbo Hissing?
Old Oct 9, 2003 | 12:10 AM
HeatStroked's Avatar
HeatStroked
Question Turbo Hissing?
I have a 2002 7.3 PSD with a Diablo 54/78 chip. 4" downpipe and exhaust, K & N filter.
Just noticed a hissing sound from the turbo that I haven't heard before. It only happens after I floor it and immediately back off to zero throttle. Sounds like a hissing sound for about 1-2 seconds.
Seems to run fine otherwise, maybe slightly rougher idle. I toggled back to stock program and it still does it but not as loud or long.
I am currently in a higher altitude then normal (6000' instead of 1200') and the temps have dropped into the 50's?
Any ideas on the hissing sound? Normal?
Thanks!
Old Oct 9, 2003 | 06:18 PM
Fortyman's Avatar
Fortyman
One of your inlet pipes is loose.
Old Oct 9, 2003 | 10:06 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's completely normal. Diesels don't have throttle plates to close off air flow suddenly. All you are hearing is it spoolng down.
Old Oct 9, 2003 | 10:49 PM
Paarrothead's Avatar
Paarrothead
Yes, the noise is normal, especially at higher altitudes when you let off on the throttle fast.
