Identifying 84 Bronco Auto Trans
Old Oct 8, 2003 | 11:17 PM
Scopie's Avatar
Scopie
Question Identifying 84 Bronco Auto Trans
Hi all.
I'm back with another question :/
I'm trying to find out which transmission i have in my 1984 bronco XLT 4X4.
the door code reads 'R' under transmission. the column shift goes from right to left, P-R-N-D-2-1
the bloke I bought the truck from originally though it was a 351 windsor with a C6... it turns out the Engine is a 351 clevo!
I blew two piston rings and am getting the engine reconditioned. I need a new torque converter for the transmission (upping the engine to 350hp) ... right now the trans & engine are in seperate states and the engine specialist wants to know what trans the torque converter will need to fit on!
how do i check?
thanks in advance
- Sean
Old Oct 9, 2003 | 04:52 PM
Franken-Truck's Avatar
Franken-Truck
probably a c6. Count the pan bolts. 17 is a c6. If you come up with 11 bolts, its a c4 (not likely, but ....). Don't know of any other 3 speed autos used in the 80's.
Old Oct 9, 2003 | 07:12 PM
andym's Avatar
andym
I don't have R listed anywhere. A C6 should be K. Look around for a ford transmission ID site and you'll find pictures of different pan shapes and bolt counts.
Also, if it's a 351C, it was swapped out. An '84 would definately have a Windsor motor.
Old Oct 9, 2003 | 07:41 PM
Scopie's Avatar
Scopie
that is interesting information about the clevo being swapped in...
when i spoke to my 'mad scientist' engine rebuilder ( www.fordmuscleparts.com.au ) he told me there's nothing you can do to a windsor that you cant do to a clevo. I'm going to get under the truck at the mechanics and count those pan bolts too, thanks for that info.
- Sean (now with 351 C )
Old Oct 9, 2003 | 07:45 PM
StrangeRanger's Avatar
StrangeRanger
If it's a Cleveland then possibly it's an FMX? If it's a big ugly cast-iron boat anchor POS, that is.
Old May 3, 2012 | 04:32 PM
Stephen L Davis's Avatar
Stephen L Davis
My 1984 Bronco XLT
My 1984 Bronco XLT has a C-6 automatic with 4:10 gears, engine is a 351 Windsor HO with a 600 cfm Holley
Old May 3, 2012 | 04:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The 351 Cleveland was not in production in 1984. If it has one it is not the original engine. The only 351 in production then was the Windsor.
Old May 3, 2012 | 05:08 PM
Twistedwrench's Avatar
Twistedwrench
FYI notice he's in Australia
, could very well be a canted valve engine as those crazy Aussies love them ....
Old May 3, 2012 | 06:43 PM
Mark Kovalsky
Then it IS a Cleveland. The Cleveland was produced in the Australian market for many years after it disappeared in the US.
Old May 3, 2012 | 06:48 PM
Franken-Truck
Was Jesus here?
This thread is one doozy of a resurrection
Old May 3, 2012 | 07:00 PM
Twistedwrench
Lol just noticed the post dates lol
Old May 4, 2012 | 12:20 AM
85e150's Avatar
85e150
Originally Posted by Franken-Truck
Was Jesus here?
Even the Pope would rep you for that one!!!!!!
Old May 5, 2012 | 01:34 PM
stuart1's Avatar
stuart1
Well somebody pushed the rock aside.
Old May 5, 2012 | 04:06 PM
projectSHO89's Avatar
projectSHO89
Pretty typical of clueless noobs....
