Sponsored by: Real Truck
Door Sensor
Old Oct 8, 2003 | 10:11 PM
Tx01powerstroke's Avatar
Tx01powerstroke
Door Sensor
Can someone tell me where the door sensor is on a 01 superduty. My door ajar light is staying on and I had to pull my fuse to turn out the dome and cargo lights. This has hapened only one time before but it stopped after I restarted the truck. Thanks for any help!
Old Oct 8, 2003 | 11:50 PM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
One word. WD-40. Common problem, easy fix. Spray it generously into the latch mechanism. Happened on my F-250 & dad's Expedition. WD-40 fixed both. Never re-occured. This fix works about 90% of the time.
BTW, Welcome to FTE.
Old Oct 9, 2003 | 06:20 PM
jaxf250's Avatar
jaxf250
Monsta - we gotta put this one in the FAQ as well.... 'less it is already there. Thx haroutd.
Tx01powerstroke - welcome to FTE!
Old Oct 9, 2003 | 09:15 PM
Tx01powerstroke
I checked that before I posted the question and didnt find it , might have just missed it. The thing was working fine today. THanks for your help
Old Oct 9, 2003 | 09:18 PM
stepman's Avatar
stepman
Powerstroke....watch out if you pull fuse 19..I believe it also works your wipers. Don't want you to find yourself with no wipers in the rain.
Old Oct 10, 2003 | 08:29 PM
Tx01powerstroke
I know it was supposed to be number 14 but that was alreadt empty it turned out to be like 3 or 4 Its still working for now thanks for all yalls help.
Old Oct 11, 2003 | 10:46 AM
get lit's Avatar
get lit
wd-40 worked on mine. Its happened a couple of times after, just keep spraying as needed!! Does anyone know what dealer says about this?
Old Oct 11, 2003 | 01:36 PM
Gordondavis's Avatar
Gordondavis
getlit-talking to a ford sevice tech. at an electrical distributor he said that is exactly what they do, and i could save money in the future by doing this to my truck.
Old Oct 12, 2003 | 10:07 PM
RedTaurus94's Avatar
RedTaurus94
Welp, I sprayed the crap outta mine, and still no light when I open the drivers door. Other three doors work fine. Should I spray it some more, or try something else?
Old Oct 12, 2003 | 10:39 PM
stepman's Avatar
stepman
I know you don't want to hear this but, I would pull the switch ( I can't remember if these are normally open or normally closed) You'll have to unplug the wire and then maybe short the wires toether to see if the switch is bad. While you're in there you'll probably want to go ahead and replace it.
