I have a 1993 f150 with a 302 i just rebuilt it and the oil pressure gauge doesnt read anything its like its not even working but if i rev it up higher it will read in the normal range and if i let the gas go it goes back to like it turned off. When it doesnt have any it like the truck is turned off its that far to the left of the L. what do u guys think i want to get it going but i dont want to drive it like that? Any help would be awesome. thanks
Well i bought a mech. gauge today and checked it and i dont have enough pressure to fill the little tube they give with it. So what should i try now because i have 0 Pressure?
Is it possible for the oil pump drive rod to get sucked up out of the oil pump into the bottom of the distributor so that it doesnt hit the pumpand doesnt get pressure
DID YOU PRIME THE OIL PUMP ??
BEFORE YOU INSTALL A NEW OIL PUMP YOU MAY NEED TO PRIME IT,JUST A SMALL AMOUNT OF GOOD CLEAN GREASE WILL START THAT SUCKER SUCKIN.IM NOT 100% SURE OF THIS BUT I THINK THERE IS A CHECK VALVE INSIDE THE OIL PUMP ALSO YOU MAY WANNA CHECK IT TOO.
