Bogs under throttle. CAN ANYONE HELP?
Old Oct 10, 2019 | 05:03 PM
xsfg's Avatar
xsfg
Its 30 psi at the rail which makes me believe its the injectors. It was my fathers truck. Its an 89 f250 460. He passed. His girlfriend wanted to sell it for 50 bucks. I took it. She stole everything else.Any way, koer codes 12
21
41
18
77 or 78?
Koeo codes
32
96
It idles fine. Timing is good. But if i push the throttle it will bog down and the fuel pressure will drop unless i let off the gas. Ive replaced maf sensor, tps, fuel filter, fuel pump, passed the broken fuel switch diaphragm so im running off front tank. Also, does the maf vacuum go to the top or bottom throttle body nipple? Thanks.
Old Oct 10, 2019 | 05:29 PM
torq'ta 5 8's Avatar
torq'ta 5 8
this will help scroll down to page 4 where 2 digit codes start
Ford OBD1 Codes and Procedure Fuel Injection Transmission (Mechanics)
Old Oct 10, 2019 | 05:35 PM
Conanski's Avatar
Conanski
You have a fuel delivery problem, fuel pressure should NEVER drop no matter what. On that truck the dual function resovoir is the prime suspect unless somebody did some stupid like eliminating 1 tank and looped the hose at the DFR.
Old Oct 10, 2019 | 05:59 PM
xsfg's Avatar
xsfg
I might be that stupid guy because i bypassed the dual function reservoir thinking that was it. I cleaned it over and over and it never worked properly i thought. The truck would stumble and overflow one of the tanks and i thought that was the culprit. I know what the codes mean. I just put them up because other people would want to know what i found in diagnostics.
Old Oct 10, 2019 | 06:59 PM
Conanski's Avatar
Conanski
You were right, if one of the tanks is overflowing the DFR isn't working correctly, that should never happen. The question now is exactly how did you "bypass" it? If you accidentally created a loop somewhere then the pumps will struggle to build pressure. There should be 40psi(V8s only.. I6 is 50psi) available at the motor at all times, the regulator reduces this to 32psi when vacuum is present at the regulator.This pressure should also remain when the engine is shut off although in your case if you have completely bypassed the DFR then that may no longer happen as it contains the check valves that make this possible. There is also a single function resovoir for this this vintage truck designed for single tank applications, this system really needs the resovoir portion as a buffer between the low pressure in-tank pump and the frame mounted high pressure pump as the high pressure pump will starve without it under some conditions.
Old Oct 10, 2019 | 07:53 PM
xsfg's Avatar
xsfg
I will check for loops. I just bought the ford fuel steel line extensions to bypass it. I didnt know there should still be a single pump reservoir there. Just in case those two arent it, what would common knowledge tell you what else it could be besides the things that ive already replaced obviously. Thank you so much for your help and timely replies.
Old Oct 10, 2019 | 07:59 PM
Conanski's Avatar
Conanski
The correct way to delete a tank is to cap the ports going to it coming out of the DFR, DO NOT loop any together.
Old Oct 10, 2019 | 09:13 PM
xsfg's Avatar
xsfg
Would that be the cause of my issue? It seems plenty of people got rid of the reservoir to a single tank system and didnt have these issues. Is that what youre getting off the codes i provided?
Old Oct 10, 2019 | 10:10 PM
Conanski's Avatar
Conanski
Yes. A good DFR will properly isolate both tanks so this may not matter but yours is malfunctioning and leaking from one tank to the other so when an input and output are looped together a short circuit is created that will bleed off pressure.
Yes.. although totally removing it may cause other issues
No, the EFI system doesn't know what components are in the fuel system and it doesn't even monitor fuel pressure. The codes you are getting may or may not be related to this problem so you may still have other things to fix but your biggest problem is definitely with the fuel system.
Old Oct 11, 2019 | 03:02 AM
xsfg's Avatar
xsfg
Ill have to hit a junkyard on payday to pick up the black canister. Will report back when complete.
Old Oct 18, 2019 | 11:13 AM
xsfg's Avatar
xsfg
I put a reservoir on it. It starts off at 20 psi but gets to 30 and steadies off. As i put throttle on it, it will slowly decrease in fuel psi. Any other ideas?
Old Oct 18, 2019 | 10:18 PM
Conanski's Avatar
Conanski
Is that the same as before or better/worse?
Do you still have any of the ports looped together? If so remove the loop and cap each one individually
Old Oct 19, 2019 | 08:34 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Just for clarification, you put a “new-to-you” DFR on it and reconnected the other fuel tank or is it still disconnected?
Old Oct 20, 2019 | 09:46 AM
xsfg's Avatar
xsfg
I unhooked the rear fuel lines, put the front tank fuel lines on a single tank reservoir instead of the oem reservoir.
Old Oct 20, 2019 | 10:07 AM
Conanski's Avatar
Conanski
You need to check that the frame mounted fuel pump is working, you should have 40-45psi at the motor all the time.
