Sponsored by: Real Truck
Bed Rail Replacement - Alignment/ Measurement Help
Old Oct 10, 2019 | 11:03 AM
blakeusa's Avatar
blakeusa
I have removed my 8ft bed and cut and ground off the 4 middle support rails - as the front and rear main supports were good.
Purchased some aftermarket rails and can't figure out a good way to align the rails before welding up.
First I can't exactly figure out the correct OEM height of the rails across the bed?
Does anyone have measurements on the bed rails from the front to the back?
Height and Length or each Rail?
And spacing from Rail to Rail?
meaning is the first one at the front of the bed
> 3.5 inches height and 6' across
> Second one at 3" height x 2.5" wide and 20 inches down from mounting hole to mounting hole.
> Etc
Any ideas on how do I make sure the rails and holes align to the frame correctly.
Thought it would be easy to match up after removal but after grinding and primer I should have double measured before removing.....
Thanks
Old Oct 10, 2019 | 11:06 AM
blakeusa's Avatar
blakeusa
Alignment Help w. Bed Rails
scottlathrop
26
Jun 3, 2019 08:19 PM
Plowjocky
Dec 20, 2016 07:22 AM
Stormj1
Feb 10, 2011 03:28 PM
jmadsen
Sep 29, 2010 07:28 PM
emeraldcoupe
Mar 19, 2010 04:39 PM
