Adjustable fuel pressure regulator
Old Oct 9, 2019 | 10:46 AM
Armyrules2's Avatar
Armyrules2
Does anyone know of an adjustable fuel pressure regulator for a 1996 4.9?
Old Oct 9, 2019 | 06:26 PM
torq'ta 5 8's Avatar
torq'ta 5 8
yours got problems? what is fuel pressure at idle? should be 50 psi or higher at idle
Old Oct 9, 2019 | 06:29 PM
Armyrules2's Avatar
Armyrules2
Well my motor is far from stock so I have bigger injectors in it after porting and polishing the head. I'd like to be able to adjust the fuel pressure because of all of my mods.
Old Oct 9, 2019 | 06:48 PM
torq'ta 5 8
if you new how many bolts hold it on, I got mine from LMR, mine is 2 bolt(93-95 lightning 5.8L)
if 3 bolt then get (87-93 mustang 5.0L) both are adjustable up to 100psi
my 5.8L had 2 bolts
this is 3 bolt 87-93 mustang 5.0L
Old Oct 13, 2019 | 10:42 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
A '96 would be the later 2-bolt FPR, so he would want this one ^^^. Mind you, I agree, there's not much reason to get an AFPR for a stock setup. More fuel will NOT yield more power.
Old Oct 13, 2019 | 10:44 AM
Armyrules2's Avatar
Armyrules2
My motor isn't stock. I'm not trying to push more fuel in I'd like to tune it back a little because I already have bigger injectors. I'd like to keep it from dumping too much fuel.
Old Oct 13, 2019 | 10:51 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
I almost mentioned that as a possible reason to get an AFPR. What size injector are you running? I've often wondered how common the vapor lock issue is with this engine, which is why Ford went with the unusually low volume/high pressure configuration.
Old Oct 13, 2019 | 10:53 AM
Armyrules2's Avatar
Armyrules2
I'm running accel 15 lb injectors. My truck runs pretty good with all the work I've done but it's running a little rich. So I'd like to dial it back a little
Brianut
22
Feb 23, 2011 05:35 PM
bigpowerstroke
Jun 16, 2004 06:49 PM
hbbowlvt
Modular V8 (4.6L, 5.4L)
Feb 12, 2004 08:54 AM
martyfowler
Feb 18, 2003 02:21 PM
