Sponsored by: Auxito
Bleeding the brakes...
Old Oct 8, 2019 | 08:12 PM
daveboley's Avatar
daveboley
I just finished replacing the entire brake system including all new stainless brake lines and all new hydraulic hoses. I did not replace the ABS unit or the Master Cylinder. We complete evacuated all the old fluid from th MC and filled it with new fluid before we started bleeding the system with a vacuum bleeder starting at the closest wheel and working our way out while we kept adding fluid to the MC reservoir never letting it go low enough to get air in the system. I have the truck on jack stands with all the rotors on. I'm pretty sure there is no air in the system. I've tried the brakes with the truck in 4WD, in gear with it in gear. The brakes quickly engage ant stops all wheels with less than 1/4 of the full pedal travel. My problem is that although there id resistance to foot pressure the pedal will eventually bottom out. The brakes still hold. I don't know if this is normal for this ABS system or if there is still a problem or the brakes were not properly bled. I'm an old guy and most of my experience has been on non ABS systems. Any thoughts on this or any proper bleeding instructions? I do remember a Ford E-350 van I had that if you pushed on the pedal long enough it would eventually bottom out. It was that way from when it was new right up through 259,000 miles on it.
Old Oct 9, 2019 | 07:50 AM
alloro's Avatar
alloro
Originally Posted by daveboley
My problem is that although there is resistance to foot pressure the pedal will eventually bottom out.
That's a sign of a failing master cylinder. BTW, the correct bleeding sequence is RR, LR, RF, LF.
Old Oct 9, 2019 | 09:00 AM
daveboley's Avatar
daveboley
Thanks Man... I was suspecting the MC might be bad but not being really familiar with the ABS system I thought I'd ask a few questions before I replaced it. Hopefully that will fix the problem.
Old Jun 8, 2023 | 07:38 PM
FordTruckChuck's Avatar
FordTruckChuck
Did that fix the problem?
exegeses
Sep 2, 2021 03:47 PM
cappo
Mar 25, 2015 07:23 AM
rkloehn
Modular V10 (6.8l)
Nov 17, 2012 10:43 AM
ramblin' guy
Oct 26, 2008 10:34 AM
1999redford
Dec 19, 2004 01:57 AM
