Modular V10 (6.8l)
No brakes after bleeding?
Old Nov 9, 2012 | 09:31 PM
rkloehn's Avatar
rkloehn
So i bled my brakes all the way around and added fluid as i went teying to get the old out and out new in. Now brake pedal goes all the way to the floor and i have almost no breaking. Along with the bleeding i did new rear rotors and pads along with driver caliper. Ive done brakes a million times but never attempted to bleed out the system and refill with new. Only mistake i made was i mixed 2 different fluid types, could this be my problem? Going to rebleed tomorrow by gravity. What do you guys think?
Old Nov 16, 2012 | 05:36 PM
WestxSRT10's Avatar
WestxSRT10
Did you mix dot 3 or 4 with Dot 5?, if you did start over. A simple one wheel at a time gravity bleed with the engine off shouldnt cause any issues.
Massive pressure changes can shutdown the ABS system on newer trucks, the dealer has to reset the system.
Old Nov 16, 2012 | 07:12 PM
dualwheels66's Avatar
dualwheels66
Use DOT 4.
Old Nov 17, 2012 | 10:43 AM
bakon's Avatar
bakon
How did you bleed them? What method, order, after parts installed, during install?
justplumducky
24
May 26, 2014 03:48 PM
rkloehn
Nov 11, 2012 06:02 PM
JoSHN
2004 - 2008 F150
Oct 1, 2011 07:29 PM
zarillus
Jan 14, 2009 12:28 PM
ThePheonixx2
19
Nov 2, 2003 02:13 PM
