Mandatory Turn Signals
Old Oct 8, 2019 | 05:43 PM
arthall's Avatar
arthall
I am pretty sure that turn signals became mandatory in the US for cars on January 1, 1953. But when were they mandatory on personal pickup trucks? I believe my 1953 F100 was built in November of 1952 and it does have turn signals. Were these factory equipment or were they dealer installed at that time? When did Ford first offer factory installed turn signals? When did they become standard equipment?
Old Oct 8, 2019 | 07:55 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
It all depends on the state, in California CVC 24951 says:
(a) Any vehicle may be equipped with a lamp-type turn signal system capable of clearly indicating any intention to turn either to the right or to the left.
(b) The following vehicles shall be equipped with a lamp-type turn signal system meeting the requirements of this chapter.
(1) Motortrucks, truck tractors, buses and passenger vehicles, other than motorcycles, manufactured and first registered on or after January 1, 1958.
(2) Trailers and semitrailers manufactured and first registered between December 31, 1957, and January 1, 1969, having a gross weight of 6,000 pounds or more.
(3) Trailers and semitrailers 80 or more inches in width manufactured on or after January 1, 1969.
(4) Motorcycles manufactured and first registered on or after January 1, 1973, except motor-driven cycles whose speed attainable in one mile is 30 miles per hour or less.
The requirements of this subdivision shall not apply to special mobile equipment, or auxiliary dollies.
(c) Turn signal lamps on vehicles manufactured on or after January 1, 1969, shall be mounted not lower than 15 inches.
So in California my '55 would not need turn signals. Like I said state dependent.
Old Oct 8, 2019 | 11:22 PM
Mixer man's Avatar
Mixer man
Here is probably more information than you want on the subject. Federal Motor Vehicle Safety Standard 108 (FMVSS 108)
https://www.govinfo.gov/content/pkg/...sec571-108.xml
Old Oct 14, 2019 | 06:13 AM
RiKi5156's Avatar
RiKi5156
My 52 F1 didn’t have them so I put in an aftermarket on the column switch and wired all accordingly. Now I have turn signals front and rear, park lights on at first detent and all working as they should. Painted the inside of the park/taillight housings white and they are very bright now. Used standard halogen headlight bulbs and all except the wiper motor (volt a drop) is 12v.
Old Oct 14, 2019 | 09:15 AM
Hanger53's Avatar
Hanger53
When I got my '53 it appeared to have had original turn signals from the factory.. Most telling, was the switch "in" the steering column that looked as if it had been there since the truck was built and it was wired for positive ground...
I've since replaced the switch with new style, 12 volt, NEG ground..
Old Oct 14, 2019 | 09:30 AM
abe's Avatar
abe
This I know. In 1953 through 1956, factory turn signals in the steering column that were self cancelling were optional. They had a turn signal switch lever that resembled the remote shifter lever with a round ****.
My 55 has the factory turn signals as described above.
My 54 have the added Signal Stat turnsignal switch strapped onto the steering column. My 54 had the TS lights mounted on top of the front fenders. I am not when these were added .... Was it done at the dealer before Grandpa bought the truck or was it done later to comply with PennDOT laws.
Old Oct 19, 2019 | 05:09 PM
arthall's Avatar
arthall
I have a question on the wiring of the rear lights. My tail light housings use a socket for bulbs with only two filaments, one for parking lights and one for brake lights. Do you simply splice the turn signal wire into the brake light wire for each side? Or does the addition of turn signals require a different socket and bulb?
Old Oct 19, 2019 | 06:09 PM
3twinridges's Avatar
3twinridges
Turn signals were an accessory option for the 48-52 trucks. They are self cancelling and the signal housing is a black matte body instead of the chrome finish. I think the chrome finish is for cars.
JB
Old Oct 20, 2019 | 10:10 AM
52 Merc's Avatar
52 Merc
It depends on the turn signal switch you have. Some are designed to integrate with the brake lights, some are made to operate totally separate with their own lamp assemblies.
Old Oct 20, 2019 | 10:25 AM
arthall's Avatar
arthall
Thanks for the info. When I bought the truck it had obviously old turn signals and two filament tail lights. They didn't work at that time, but if I assume they did at one point I guess that they integrate with the brake lights.
Old Oct 20, 2019 | 10:30 AM
52 Merc's Avatar
52 Merc
Two filament tail lights does not mean you have turn signals built in. Any normal tail lamp will have a two filamant bulb for park and brake light circuits.
Old Oct 20, 2019 | 11:27 AM
arthall's Avatar
arthall
Yes, I understand. But I am assuming the turn signals on the truck once worked with a 2 filament bulb, so they must have been wired with turn signals and brake lights on the same filament.
Old Oct 21, 2019 | 09:08 PM
RiKi5156's Avatar
RiKi5156
They are. I bought an aftermarket unit from jegs or summit can’t remember but it was $25 has the wiring diagram and the taillight bulbs have to be changed to 12v. Look carefully and I think your stock sockets have the pins straight across so you’ll have to get new bulbs with the same alignment.
Old Oct 21, 2019 | 09:37 PM
Mixer man's Avatar
Mixer man
Nope. The bulbs with pins straight across are single filament bulbs. You will need #1154 6 volt or #1157 12 volt.
VCF3
Jun 8, 2014 07:13 PM
XXX4play
2009 - 2014 F150
21
Apr 15, 2011 10:15 PM
Kurt G.
Jul 4, 2007 01:48 PM
sixte1f100
Apr 28, 2000 10:13 PM
