Bulletproof mud flaps
Old Oct 6, 2019 | 10:03 PM
Bkmax's Avatar
Bkmax
Anyone running Bulletproof mud flaps or have knowledge of them? I did several searches and most posts Re: Bulletproof are several years old. I like the look and from what I have read, they are quality. Posts state they are expensive, but then you get what you pay for. Also, manufactured in Alberta Canada. Several questions. Are they comparable to Gatorbacks, because Gatorbacks are my second choice? What is difference in pricing? Gatorbacks come with mounting hardware for existing holes. Do Bulletproof come with hardware or do you have to drill? Will order a 2020 and plan to purchase mudflaps beforehand. Any assistance would be appreciated.
Old Oct 7, 2019 | 09:05 AM
Frac Master's Avatar
Frac Master
I currently run Bulletproof mudflaps. I love them, had the Gatorbacks from the dealership. No comparison, I drive a lot of gravel and the Bulletproof take it like a champ. Pricing I believe they are close to the same. Bulletproof does not use the no drill mounting bracket. They use stainless steel that drill right into the truck. Since I had the no drill brackets from my Gatorbacks I used them to mount my Bulletproof ones. This was all back in 2017, maybe Gatorback has came out with a kickback style since then but what I like is the bulletproof are custom width and length. My next truck ill be drilling in the bulletproof mudflaps before I leave the lot.
Old Oct 7, 2019 | 03:23 PM
Bkmax's Avatar
Bkmax
Thanks Frac Master. Yes, Bulletproof do come in kickback. You mention custom. They seem to have two lengths from all pics I have seen. I prefer the shorter as the long will provide more coverage, but too long IMO. Do you have pic. Did you purchase direct because there were posts that persons had difficulty in purchasing? Also if I purchase, if needed I will try the Gatorback mounting system.
ruschejj
6.7L Power Stroke Diesel
Apr 28, 2012 06:13 AM
wildjon300ci
Georgia Chapter
May 1, 2007 08:04 PM
SIXD9R
Aug 7, 2003 08:20 PM
