A/C cut off.
Old Oct 5, 2019 | 03:42 PM
Gstan's Avatar
Gstan
A/C cut off.
As you know when you use lots of power (on a hill etc) the A/C cuts off evidently to give more power to the drivetrain. Is there any way to bypass that so the A/C stays on 100%?
Thanks
Old Oct 5, 2019 | 04:53 PM
sloopdog1's Avatar
sloopdog1
Ummm, never heard of that one. Exactly how does it cut off, does the compressor stop, or does the air stop blowing from the outlets?
Old Oct 5, 2019 | 04:55 PM
R&RFord's Avatar
R&RFord
The AC cutoff doesn't kick in all that often. Most people would never know it existed.
But a vacuum leak will cause the AC to come out of the defrost vents under moderate engine load like climbing a hill.
Old Oct 5, 2019 | 04:56 PM
My4Fordtrucks's Avatar
My4Fordtrucks
At WOT the compressor clutch disengages.
Old Oct 5, 2019 | 05:22 PM
Gstan's Avatar
Gstan
That's it. So what, I live with it?
Old Oct 5, 2019 | 09:15 PM
My4Fordtrucks
I would question why you are driving around with the gas pedal always mashed to floor? The truck is either down on power because something is wrong or you are overloading the truck.
Old Oct 6, 2019 | 05:16 AM
sloopdog1's Avatar
sloopdog1
Well, mine must be broke, it never did that. Nor any other vehicle I ever owned. I have had some that would act strange because of vacuum loss at WOT.
Old Oct 6, 2019 | 05:27 AM
sloopdog1's Avatar
sloopdog1
Just to test the AC for WOT protection, Unplug the connector at the AC compressor then run a wire from the battery thru a fuse and a switch to the ac compressor, (make sure the AC clutch engages when you turn the test switch on) that will remove any WOT shut down sensor from the AC circuit. Yes, this is a small bit of work, but it will tell if the AC clutch is disengaging.
Old Oct 6, 2019 | 08:50 AM
Gstan's Avatar
Gstan
I can do that. It's how I got freon into the system when I bought the truck. That's a good idea. I could run it off a relay so the system will be protected.
Thanks
Old Oct 6, 2019 | 09:21 AM
My4Fordtrucks
I could run it off a relayso the system will be protected.
Thanks
Relays don’t technically protect anything. That’s what fuses and / or circuit breakers are for.
It’s your truck but I still don’t understand why the compressor temporary shutting off is an issue.
Old Oct 6, 2019 | 11:29 AM
Gstan's Avatar
Gstan
Guess you have to be there.
Old Oct 6, 2019 | 12:04 PM
R&RFord's Avatar
R&RFord
To actually make an attempt to help you.
Are you actually flooring the throttle when you experience the problem and only when you floor the throttle? Does the AC actually cut out? Are you sure it is not coming out of the defrost vents? Does the fan keep blowing but the air comes out warm?
Old Oct 6, 2019 | 12:56 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Here's what I think is going on, when you rev your motor high it spins the compressor faster, so it's sucking down lower pressure on the low side and if it goes low enough the compressor will be shutoff by a low pressure cutoff switch (if equipped) and it will wait until it sees 35-55 psi to reengage the compressor, this is a safety thing to prevent damage.
Gstan's Avatar
Gstan
No, not WOT, no air from any of the vents. Just like I turned off the switches. Happens whenever I climb a hill from moderate to steep. Mind you it's a six-cylinder with a 3.08 rear end so it takes a bit of power to get up a hill.
Old Oct 6, 2019 | 01:22 PM
sloopdog1's Avatar
sloopdog1
Mine is a six-cylinder 5 speed with a 3.08 rear end, and I have never had that happen. I think (for all that's worth) you have a vacuum leak, when you throttle up to climb the hill, vacuum drops and the doors that control the airflow are shutting, because there is not vacuum enuff to hold them in position.
