A/C cut off.
Old Oct 6, 2019 | 01:35 PM
White 97 xlt's Avatar
White 97 xlt
Originally Posted by Gstan
No, not WOT, no air from any of the vents. Just like I turned off the switches. Happens whenever I climb a hill from moderate to steep. Mind you it's a six-cylinder with a 3.08 rear end so it takes a bit of power to get up a hill.
Originally Posted by sloopdog1
Mine is a six-cylinder 5 speed with a 3.08 rear end, and I have never had that happen. I think (for all that's worth) you have a vacuum leak, when you throttle up to climb the hill, vacuum drops and the doors that control the airflow are shutting, because there is not vacuum enuff to hold them in position.
^^^ X2 ^^^
blowhole
Mar 10, 2013 12:13 PM
dtilden
1997 - 2003 F150
Mar 28, 2003 07:39 PM
