will this fit
Old Oct 5, 2019 | 01:17 AM
jerryst's Avatar
jerryst
will this fit
Hi someone on Craigslist is selling a 1950 rear reproduction bumper. Will this bumper fit a 1955 Ford F100? I thought I read that bumper up to 1970 will fit my 55 F100?
Thanks
Jerry
Old Oct 5, 2019 | 07:45 AM
GreatNorthWoods's Avatar
GreatNorthWoods
It's not the right bumper but a lot of trucks came with no rear bumper at all. If the bumper is a good deal and you are up to a little fabrication work I son't see why you can't make it work but don't expect it to be a bolt-on. It might be a tad shorter than a 55 bumper since the 48-52 trucks were narrower.
Old Oct 5, 2019 | 08:39 AM
abe's Avatar
abe
There should be lots of steel 53-72 bumpers around that guys are willing to sell. A lot of guys replace theirs with new stainless or chrome. So if you want a black painted bumper I'm sure you'll find one. Even repops are only around $99.
Old Oct 5, 2019 | 03:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
BBAA-17906-A .. Painted Channel type Rear Bumper / Obsolete
1948/52 F1/F3 // 1953/56 F100/350 // 1957/72 F100/350 Flaresides // 1961/63 F100/250 Uni // 1973/76 F250 4WD Flaresides.
1977 F250 4WD Flaresides before serial number Y20,001 // All these 1973/77 F250 4WD's are known as High Boys.
Upper pic from 1973/79 catalog shows channel bumper F100 & F250 Flareside (body style 83) applications, but it wasn't used on F100's after 1972.
Old Oct 5, 2019 | 04:14 PM
56panelford's Avatar
56panelford
At the front frame rails only..
Old Oct 6, 2019 | 06:38 AM
bigwin56f100's Avatar
bigwin56f100
Looks like a channel bumper was used in 1978
Ford brochure
Old Oct 6, 2019 | 12:59 PM
NumberDummy
Originally Posted by bigwin56f100
Looks like a channel bumper was used in 1978.
Yes, but it won't fit the OP's application.
1973: Ford increased the width between the inner frame rails behind the cab from 33 1/2" used 1972 and earlier to 37 1/2" on the following:
1973/79 F100 2WD/4WD, 1975/79 F250 2WD, 1975/79 F150 2WD/4WD, 1977 F250 4WD from serial number Y20,001, 1978/79 F250 4WD
The Styleside & Flareside bumpers are different, the brackets are different.
1973/79: The only trucks that used the BBAA-17906-A Flareside rear bumper were 1973/77 F250 4WD's aka High Boys, because they retained the 33 1/2" frame rails.
Old Oct 6, 2019 | 01:15 PM
bigwin56f100
I’ve used that later bumper several times. You just have to make spacers and the brackets actually are better as they make the bumper closer to the bed for the custom look
and I was just stating the facts that A channel bumper was used later. I never said it was exactly the same as the 72 and earlier
Old Oct 6, 2019 | 07:29 PM
jerryst's Avatar
jerryst
Ok so if ai understand correctly I can use up to a 1972 ford bumper for a f100? I have the original rear bumper brackets.
Thanks
Jerry
sitInHigh
Jul 24, 2013 08:40 PM
70_F250_390
Mar 10, 2011 10:54 AM
ssanto
Jun 13, 2006 05:38 PM
BB1
Apr 9, 2005 10:09 PM
