74 highboy replacement panel
Old Sep 26, 2019 | 12:48 PM
bassmasterdude's Avatar
bassmasterdude
I am having a hard time finding a bed in my area that is better than the one I currently have. The main issue with mine is a previous owner smashed in the center stake pockets and also the top of the wheel well so he could install propane tanks on both sides. I can get replacement inner bed side panels from LMC but I have never replaced one before. Does anyone have any experience at this? If so is it quite a bit to tackle?
Old Sep 26, 2019 | 01:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/76 F100/250 2WD & F350 (except 140" wheelbase) 8' Styleside beds are the same, but High Boys have a narrower rear frame width behind the cab (33 1/2" vs 37 1/2").
So the mounting holes in the bed are in a different location.
Old Sep 26, 2019 | 01:42 PM
73GreenBean's Avatar
73GreenBean
Not sure about replacing the entire upper portion above the dent but the wheel wheels are fairly simple it's just a time consuming process to get the edges feathered with body filler. Here's mine I just did this summer
Old Sep 26, 2019 | 01:52 PM
bassmasterdude
So the part that I need to replace is on the inside of the bed not the outside. LMC sells an entire inside side panel that has the stake pocket and wheel well full length. I will not need to replace the exterior panel.
fordtrckman1977
Aug 21, 2013 10:44 PM
Riskyguy
Jun 17, 2011 08:06 PM
bucks77ford
Paint & Bodywork
Jun 23, 2006 06:30 PM
