Over heating issue
Old Sep 27, 2019 | 02:51 PM
Dynexmidnight's Avatar
Dynexmidnight
I replaced the temp sensor, it isn’t climbing as fast but still going up
Old Sep 27, 2019 | 02:55 PM
Hit Man X's Avatar
Hit Man X
Which way did you install the thermostat?
Old Sep 27, 2019 | 04:31 PM
Dynexmidnight
With the bleeder to the left side of the truck like they said at the ford dealership
Old Sep 27, 2019 | 07:58 PM
z31freakify's Avatar
z31freakify
Have a temp gun? Aim it directly at the thermostat housing when your truck is "overheating" to verify it's actually over heating.
Old Sep 30, 2019 | 12:16 AM
Dynexmidnight
Just found some stuff hanging out of the radiator, looks like some stop leak to be honest. I think the radiator is clogged up. I’m gonna get a new one tomorrow and see if that helps, if not I’m gonna go get a new water pump to.
Old Sep 30, 2019 | 07:45 AM
Talyn's Avatar
Talyn
oh god, stop leak ruins motors.
Old Sep 30, 2019 | 09:47 AM
Hit Man X's Avatar
Hit Man X
Go ahead and replace the heater core also. They are about $25. At least install new heater hoses, I paid about $1/foot ... 5/8" sticks in my mind as the correct size.
New radiator hoses would be prudent, I did on mine soon after purchase.
Old Sep 30, 2019 | 05:30 PM
Dynexmidnight
As good as this motor runs, I don’t think anything major has happened to it. For one it doesn’t use any oil or coolant, no blow by, no loss of power at all. Plus if it was over heating because of stop leak (which it shouldn’t) then it would be much worse. The truck all around is to good to be a lemon. Not trying to jinx myself at all. This truck made a 22 hour round trip to Tennessee and back with no issue but the small over heating thing. Also when I run at night it stays a little cooler. I’m pretty sure it’s a radiator.
Old Sep 30, 2019 | 07:02 PM
Talyn's Avatar
Talyn
Well, here is the thing, again,
You don't actually know if its overheating at all.
Old Oct 1, 2019 | 10:59 AM
knottyrope's Avatar
knottyrope
Old Oct 10, 2019 | 02:24 PM
Dynexmidnight
Ok I’m pretty sure it’s the radiator to be honest. The cooling system isn’t holding the amount of coolant it should be. I can barely get 4 gallons in the system and if I’m not mistaken it’s supposed to hold 6 or 7 gallons. Correct me if I’m wrong. I ordered a brand new full aluminum radiator and a laser thermometer to. I’m going to go ahead and order a water pump anyways cause even if the radiator fixes it I want to go ahead and replace it. Wish me luck and if there are any things I need to know please tell me.
Old Oct 11, 2019 | 07:36 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Old Oct 11, 2019 | 03:31 PM
  #28
knottyrope's Avatar
knottyrope
week after my WP replace, my rad got a hole
I flushed it again and was surprised at what gunk came out
Old Oct 13, 2019 | 02:29 PM
  #29
Dynexmidnight
I flushed the radiator 3 times, also when I flushed it the first time it wasn’t rusty at all or even gunky. It was white and chalky looking. The truck has a new water pump on it and I don’t think it’s bad. I ordered a water pump so I have it. When I put the new radiator in it I’ll get some more additive to add to the coolant. I use 50/50 in all of my vehicles. After I get the new radiator in and make sure it doesn’t leak or anything I’m gonna pop the plastic off of the top of my old one and see how many channels were clogged.
Old Oct 13, 2019 | 02:35 PM
  #30
Dynexmidnight
Also I noticed that the top and bottom of the radiator are pretty hot. I’ve been told that the bottom should be cooler than the top but it seems it’s pretty hot like the top or is that normal. That’s from me feeling it with my hand anyways.
